Need spark plug size info
Old Mar 8, 2007 | 09:39 AM
MELVIN's Avatar
MELVIN
Default Need spark plug size info
This is for totally non vette related spark plug, but I need basic info
I need spark plug numbers, or brand (I dont care what brand, make, heat range, reach,etc)
that would take the typical 5/8 size socket to remove
Actually, if you can positively identify a make/model/size engine hat takes this basic size, that would be even better
Old Mar 8, 2007 | 10:00 AM
Durango_Boy's Avatar
Durango_Boy
Most ANY GM motors use 5/8" tools. Are there any other limiting factors? Maybe plug length? What's it gonna be used for?
Old Mar 8, 2007 | 10:01 AM
GDaina's Avatar
GDaina
all GM products, from 86 to present, maybe even earlier use the 5/8 plugs
Old Mar 8, 2007 | 11:02 AM
MELVIN's Avatar
MELVIN
Fellas,
Heres the deal. I wish I had my tools with me know, since Im embarrassed...............
I have done so much wrenching, its become automatic, so I just dont remember the actual size
Here is what I need, in basic terms, (not remembering actual sizes, and I could be wrong on the 5/8 thing
There are two basic size spark plug sockets out there. There is a large one, and a smaller one
I need spark plugs that would fit the larger one....Again, I dont care about heat range, or length of reach, etc
That being said, if you could tell me what make/models might cover this "large spark plug socket category" is enough.............
Old Mar 8, 2007 | 11:45 AM
Mark_Milner's Avatar
Mark_Milner
Chevys had a 5/8" and a 13/16" hex plug, depending on year. However, there is a lot of differences beyond that.
First there is heat range. Too hot or too cold and you have problems running, or even getting running.
Length is a factor. Some extend further in, which means in the wrong engine, the piston can hit the plug and could damage the engine.
You need to have more information than this.
Old Mar 8, 2007 | 11:51 AM
Durango_Boy
I agree...what motor is this for? Any Oreilly or Autozone can look up the proper style plug for any car, truck, or lawn mower. Then it's up to you to decide on a brand. NGK is a favorite of mine.
Old Mar 8, 2007 | 03:00 PM
MELVIN's Avatar
MELVIN
Thanks,
As I said, Heat range, reach, etc is NOT factor in what I am doing.
13/16 is the answer I was looking for
Old Mar 8, 2007 | 03:44 PM
Durango_Boy
Thanks,
I sent you an email responding to you about the 13/16" thing but that email address came back invalid.
To Need spark plug size info
