Winter Storage Removal
Old Mar 8, 2007 | 05:01 PM
Mick42767's Avatar
Mick42767
Default Winter Storage Removal
OK, with the warm weather a few weeks away, I am getting ready to remove my '72 from its long winter nap. Anybody have a procedure or checklist that they follow? Main concern is making sure that the engine is properly lubricated before starting her up. Keep in mind that I am not that mechanically inclined, so I will not be pulling off the heads, removing the cam, etc. Thanks in advance!
Old Mar 8, 2007 | 05:18 PM
SEVNT6's Avatar
SEVNT6
One thing I've done from day one is to let it crank over until I get oil pressure. And then some. Mine won't start unless I give it gas. Also the annual caliper leak check..........
Old Mar 8, 2007 | 05:28 PM
stingraymaniac's Avatar
stingraymaniac
i always pull the ignitor plug from the distributor and let the car crank until it gets oil pressure,after that i start it and look for gas leaks and water leaks check all the fluids and tire pressure.i let it idle a couple of mins before i move it....
Dammit now i want it to be summer even more
Old Mar 8, 2007 | 09:15 PM
hutch70's Avatar
hutch70
First thing I do is check for critters. Then crank to circulate oil. Check for leaks/fires. Make sure tires have good pressure/ make sure it rolls and go have fun.
Old Mar 8, 2007 | 09:19 PM
Mick42767's Avatar
Mick42767
When you say "crank", do you mean turn the key just enough so that it doesn't catch?
Old Mar 8, 2007 | 10:08 PM
SEVNT6's Avatar
SEVNT6
The engine turning over without starting.....
Old Mar 8, 2007 | 10:16 PM
SIXFOOTER's Avatar
SIXFOOTER
If its been sitting for a few weeks or even several months all ya have to do is a critter and fluid level check and fire it up. A motor with some miles on it will sit for an extended time and be just fine on start up. These things are not thermonuclear devices, just an engine. Its simpler than some make it.
Old Mar 8, 2007 | 10:21 PM
Big2Bird's Avatar
Big2Bird
Well put. Just start it after checking fluids. If it sat that long, it will prime the oil before it primes the carb.
Old Mar 9, 2007 | 08:05 AM
lvrpool32's Avatar
lvrpool32
Check oil level, check radiator level, remove air cleaner, remove coil lead, check battery level and turn over until the oil pressure builds up...wait a 20 seconds, put the coil lead back on. Turn over, let it fire and then run for 30 seconds, turn off, check for leaks (fuel lines have a habit of shrinking and becoming loose). No leaks, start and let idle, keeping an eye on the temp gauge and for other leaks.
Old Mar 9, 2007 | 08:47 AM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
How true. Mine has only been sitting idle about 2 months since the last start up. I'm gonna try to fire her up on Sunday, supposed to be 50+ deg.
Old Mar 11, 2007 | 12:26 AM
SIXFOOTER's Avatar
SIXFOOTER
Mine sat for a year before I started it to bring it in the garage to start the rebuild, started and idled after turning over a few times.
To Winter Storage Removal
