stuck trailing arm bolts
Old Mar 9, 2007 | 08:47 PM
elecriciandude's Avatar
elecriciandude
Default stuck trailing arm bolts
Hey Guys, besides P/B to help loosen the bushing bolts, what insight do I need to get those crusty bolts out,thxs ahead of time, Terry
Old Mar 9, 2007 | 09:07 PM
Durango_Boy's Avatar
Durango_Boy
A Sawzall and a demolition blade will work wonders.
Old Mar 9, 2007 | 10:03 PM
eastltd's Avatar
eastltd
I tried the sawsall but found I had bought blades that were too short. Since I was planning to replace the bushings anyway, and the shims were rusted away, I burned the bolts out with a torch. It wasn't pretty and some may call me "Bubba", but it got the job done quickly!
The final installation with new stainless shims and TA bolts looks great. No signs of "Bubba" in the end.
Good luck
Old Mar 9, 2007 | 10:14 PM
scottw's Avatar
scottw
I think most will say a sawzall. Mine is at the shop right know getting the same thing done. They are cutting them out with a sawzall. If you use a torch or any type of heat be very, very careful. Heat and fiberglass don't mix well.
Old Mar 9, 2007 | 10:17 PM
JustForFun's Avatar
JustForFun
i drive mine out with an air hammer
Old Mar 9, 2007 | 10:28 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
A couple of 8" bi-metal Sawzall blades from ACE Hardware will work wonders.
Old Mar 9, 2007 | 10:31 PM
eastltd's Avatar
eastltd
Good point! I had the body off the chassis when I did mine.
Old Mar 9, 2007 | 11:33 PM
elecriciandude
thxs guys, I should have thought of the sawz-all.
Old Mar 9, 2007 | 11:57 PM
yukon988's Avatar
yukon988
I sawzalled one side. The other side seemed a little looser so I worked at it and finally got it out. The sawzall side took about 20 minutes, the other side took a few hours. I ended up replacing both bolts. I wish I would have sawzalled both sides.
Old Mar 10, 2007 | 12:00 AM
JustForFun's Avatar
JustForFun
an air hammer will punch them out in about 2.5 secs
Old Mar 10, 2007 | 01:14 AM
Durango_Boy
If you get some Demolition blades...you'll be fine. They're long enough and designed to cut through almost anything.
Old Mar 10, 2007 | 01:51 AM
Big2Bird's Avatar
Big2Bird
That's a little overkill. I use metal blades for metal, demo blades for stucco. 18T metal will blow it out.
Old Mar 10, 2007 | 02:29 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
If the bolt isn't rustwelded to the bushing sleeve. Many of ours are. No force in the universe was going to separate them on my car, and it isn't very rusty on the underside.
Old Mar 10, 2007 | 10:18 AM
Durango_Boy
What's with the Mr. A?
Old Mar 10, 2007 | 11:20 AM
Duke94's Avatar
Duke94
Yep, sawzall does the trick.
Old Mar 10, 2007 | 01:39 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
http://www.dialbforblog.com/archives/297/
Old Mar 10, 2007 | 10:35 PM
elecriciandude
Default threads or not
One more question, does the hole the bolt go thru have threads or is it just a bolt hole.can't tell by looking at it
To stuck trailing arm bolts
Old Mar 10, 2007 | 10:42 PM
'Bochawa72's Avatar
'Bochawa72
This is the only thing so far I took my car to the shop for. He said mine were pretty rusty and he had to cut em off with a plasma cutter. Glad I didn't try that one myself!
-CR
Old Mar 10, 2007 | 11:20 PM
SIXFOOTER's Avatar
SIXFOOTER
No the hole is not threaded, the bolt is only secured with a castle nut and cotter pin on the outboard side
Old Mar 11, 2007 | 12:02 AM
rudolph schenker's Avatar
rudolph schenker
Sawzall for me too!
