Sandblasting
Old Mar 10, 2007 | 10:02 AM
stinger12's Avatar
stinger12
Default Sandblasting
I've heard that sandblasting can easily ruin regular fiberglass panels, but what about SMC panels? My 1976 vette is all SMC and if sandblasting will not harm the shell, then I mine as well strip the bondo infested front end that way. Any thoughts?
Old Mar 10, 2007 | 10:08 AM
Artsvette73's Avatar
Artsvette73
I would not recommend it. Doesn't matter glass or smc. My first one I used paint stripper for glass because it had multiple layers of paint. The second one I sanded only had one.
Old Mar 10, 2007 | 10:10 AM
Belgian1979vette's Avatar
Belgian1979vette
Hi,
I did one of mine once, after I had the guy do a test on low pressure blasting. The test was fine, but the body was ruined after he did the job. There were three layers on mine and since the job did proceed fast enough (he made a fixed price) he decided to use a stronger blast media and more pressure. Result : the body was a total loss.
Point is : it can be done if done correctly (all depends on blast media, pressure and the opening they blast with) but it all depends on the person involved and that's were most of the time it goes wrong.
I advice against it. Period
Yves
Old Mar 10, 2007 | 10:24 AM
tobyte1's Avatar
tobyte1
Do not sandblast fiberglass! Chemical strip (Cap'n Lee's fiberglass stripper), or razor blade and sand the paint off. Even at low pressures, blasting will texture and gouge the fiberglass.
Old Mar 10, 2007 | 10:47 AM
Big2Bird's Avatar
Big2Bird
Sanblast NO. Media blast is ok.
Old Mar 10, 2007 | 07:05 PM
stinger12's Avatar
stinger12
What's the difference?
Old Mar 10, 2007 | 07:11 PM
tobyte1's Avatar
tobyte1
Media blasting includes all types off media: soda, plastic, glass beads, black beauty,walnut shells, corn cob, etc .The only one that I have heard of that might be safe for fiberglass is soda blasting and even with that you have to have someone that knows what they are doing.
Old Mar 10, 2007 | 08:02 PM
harrin's Avatar
harrin
I agree, that is how I did mine, turned out OK, some deep spots, but pretty good. Lots of fun getting the soda powder out of cracks, need a good compressor with lots of time to blow out.
Old Mar 10, 2007 | 08:41 PM
Mark G's Avatar
Mark G
Capt'n Lee's worked fine on my jambs and places where there weren't very many layers, but where it was REALLY thick, it wasn't very effective. I used Kleen Strip (fiberglass-safe type) and let it soak an hour. It still took two applications, but worked great. I think I had the whole car stripped in a good long day.
No way would I sandblast fiberglass. Besides that you'll probably ruin the body, you'll get sand everywhere and it tends to raise heck with seals aii moving parts. The time/energy you will probably have to put into re-doing bodywork to straighten it out, and problems it might raise with other mechanisms, I don't think there's any gain.
Just my take.
Mark G
Old Mar 11, 2007 | 12:38 AM
82MDVette's Avatar
82MDVette
Sand is too course, use media blasting. I razor blade 3 layers of paint off of my 82
Old Mar 11, 2007 | 12:43 AM
stinger12's Avatar
stinger12
Can I use a regular pressure sand blaster with just a different media...such as soda. I Just want to do small parts of fiberglass...nothing really big.
Old Mar 11, 2007 | 01:06 AM
Big2Bird's Avatar
Big2Bird
Try crushed Walnut Shells. ...Hungry?
To Sandblasting
