454 Characteristics
Old Mar 10, 2007 | 11:34 AM
Scottys72's Avatar
Scottys72
Default 454 Characteristics
I'm looking at a '72 Coupe 454 LS-5 auto - and I know nothing about Chevy BB's.
What features do they have?
2 bolt or 4 bolt mains?
HP and TQ numbers?
What kind of mileage should I be looking at for rebuild?
TIA
Scott
Old Mar 10, 2007 | 01:35 PM
CCrane65's Avatar
CCrane65
HP and TQ numbers?
TIA
Scott
Scott, Chevy Big Blocks are just that, large engine blocks. They have more torque than the small blocks of the same year. For instance, the 72 454 has 455 foot pounds of torque and 270 horse power net.
They have 2 bolt mains with the exception of the LS-6 from 1971.
They also generate a ton of heat.
They are about 100 pounds heavier than a small block so expect some front end push in corners if you're doing any road racing.
Expect to pay $5-$10K more for an original engine big block car than for a small block in similar shape. Especially for cars with A/C and a 4 Speed.
What you pay always depends on condition, original parts and what's missing and of course documentation.
cc
Old Mar 10, 2007 | 01:49 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Plus BB's are cool.
Old Mar 10, 2007 | 03:16 PM
DJ Dep's Avatar
DJ Dep
St. Jude Donor '05-'07
Originally Posted by Jughead
Plus BB's are cool.
Oh YEAH!!!
And aluminum BB is even LIGHTER than SB!!!
Dep
Old Mar 10, 2007 | 03:38 PM
SEVNT6's Avatar
SEVNT6
Big Blocks..........
They're great motors Scott....
Old Mar 10, 2007 | 04:52 PM
Scottys72's Avatar
Scottys72
Two bolt shouldn't be a problem as far as power is concerned, I mean a good set of heads and with that swept area It should make a ton of power (not that 455 ft-lbs of torque isn't already) even if I'm only spinning it to 6K.
MMMMmmmmmmm........Big Block.......
Was at Sanair a couple years back and one of the Dragsters was a solid lifter 454 69 Camaro - now I love the sound of a Ford 289 at 7K but that Bowtie was shaking the ground beneath me.......
Thanks all
Scott
Old Mar 10, 2007 | 08:36 PM
DJ Dep's Avatar
DJ Dep
For "street use" (whatever that means), the 454 oval port heads and 2-bolt main engines are popular. You can get plenty of different manifolds and performance parts for that motor. Personally, I think tooling around on the street with a motor like that is kind of a waste. For true performace (as in RACING ON TRACKS), the only way to go is a 4-bolt main block and rectangular port heads. They have MONSTER ports and gigantic valves rivaling even the 426 hemi in breathing ability.
Dep
Old Mar 11, 2007 | 03:57 AM
jr9170's Avatar
jr9170
From: YANKEES UNIVERSE 70 454-LS5 500 ft-lbs Torque
Plus BB's are cool.
Old Mar 11, 2007 | 10:04 AM
Ironcross's Avatar
Ironcross
All engines get hot, so a statement that they get hot is correct. The kicker is that they all do. I dont care what you have, but one is not worse than the other. I have 6, yes 6 big block cars from 270 HP in my El Camino to whatever in my Vettes and Camaros. NONE overheat and all have stock cooling systems. The only people that will complain about BB Chevies are those that are jelious because they dont have one. Basically it boils down to two types of Vette owners. Those that have one and those that want one. If any are left over, the rest are liers.
Old Mar 11, 2007 | 04:34 PM
Big2Bird's Avatar
Big2Bird
Absolutely. In fact, the demand is so great, all cars came with them. 350 parts are extremely hard to find. 454's are common as cord wood because everyone wants one.
Old Mar 11, 2007 | 09:56 PM
CCrane65's Avatar
CCrane65
I wasn't talking about over heating. My 72 454 doesn't overheat either but it sure keeps the passenger compartment warmer than my 65 small block did. Maybe it's because there's more mass to a bb than a sb.
It's a bigger heater that's all there is to it.
Old Mar 12, 2007 | 12:20 PM
Scottys72's Avatar
Scottys72
Ok Easy Guys - I was just looking for tips on where to look for problem areas on the 454 - compression and leak down tests, common failures - that sort of thing - didn't want to start a BB vs SB thing......
Scott
Old Mar 12, 2007 | 12:39 PM
DJ Dep's Avatar
DJ Dep
Scott
Oh GEEZ...stops being so touchy-feely. START a big block rules and small blocks suck thread
Dep
Old Mar 12, 2007 | 06:04 PM
72 LT1's Avatar
72 LT1
I WANT ONE!! I want another vette in the garage , this time a BB to keep my ZZ4 SB company.
Old Mar 12, 2007 | 08:05 PM
Scottys72's Avatar
Scottys72
DJ my Buddy runs a 427 smallblock stroker Chevy pulling 680hp on the motor and somewhere around 1050hp on the second solonoid.....That's a smallblock Baby!!!!
I agree though - Big Blocks Rule!!
Scott
Old Mar 12, 2007 | 08:48 PM
fotyfobravo's Avatar
fotyfobravo
From: Lake Arrowhead - Georgia > 72 Base Coupe & 74 BB Roadster
We are fortunate to have 2 Vettes. I love em both. A 53,000 mile ...loaded...72 small block that looks like new. We seldom drive it since we got the 74 BB Roadster.
Old Mar 12, 2007 | 09:03 PM
73-84 IMSA Widebody's Avatar
73-84 IMSA Widebody
If the price is right, if the car is nice, yadda yadda yadda, the big block is the right choice. If you are interested in doing some mods, converting a 2 bolt to a better than 4, 4 bolt is relatively easy by any competant machine shop and how too's are readily available. There are more options than you want to know for engine system upgrades.
Good luck
To 454 Characteristics
Old Mar 13, 2007 | 04:16 AM
mfgaffney's Avatar
mfgaffney
Scott
Scott, I have a 74 BB coupe that I have owned for 15 years. It has been nearly maintenance free. I don't race it, but I don't baby it either. It has great low end torque, and is fun to drive. I get 14mpg if I cruise at 65, and 11mpg around town, normal start/stop. I do have a/c. It does produce a ton of heat in the cockpit, so did my 73 small block. I have replaced water pump, alternator, radiator, rebuilt distributor, and a complete suspension re-do(trailing arms, emerg brake, u-joints, ball joints,etc) because it is 33 year's old.
Any other vette problem will not be related to 350 vs 454. Hope this helps.
Old Mar 13, 2007 | 07:24 AM
Scottys72's Avatar
Scottys72
It does MF - that was one of the answers I was hoping for, thanks.
Scott
Old Mar 13, 2007 | 09:39 AM
early shark's Avatar
early shark
I can personally tell you, having owned 3 '70 LS5 coupes, 2 '71 LS6 coupes, 1 LS5 coupe and 2 '72 coupes, that the big block engine option in a car with A/C will heat up the inside cabin area a lot more than a car without A/C. THAT'S because there are NO operating fresh air vents down in the footwell areas. The fresh air vents makes a huge difference in keeping the inside cabin cooler with a big block engine. I personally will never own another big block A/C equipped car again.
