anything here to worry about?
Old Mar 10, 2007 | 04:33 PM
michael c. volpe's Avatar
michael c. volpe
Default anything here to worry about?
i think maybe somebody painted this, with the wrong type of paint???
notice anything i should be worried about? i found that the bolts were rusted (surface rust) inside the kick plates, but everything around it seemed fine. any help would be appreciated.
thanks,
mike
Old Mar 10, 2007 | 05:59 PM
SEVNT6's Avatar
SEVNT6
Looks like time for new body mount bushings..........
Old Mar 10, 2007 | 09:07 PM
VettePower's Avatar
VettePower
Looks like basice surface rust. No problemo!!
Old Mar 10, 2007 | 09:30 PM
David Ey's Avatar
David Ey
wire brush the rust off, wash it and paint.....maybe use por15
Old Mar 10, 2007 | 09:50 PM
tobyte1's Avatar
tobyte1
Doesn't look too bad. Do need body mount bushings, but the rust isn't too bad. Doesn't look cancerous.
Old Mar 10, 2007 | 09:52 PM
72LS1Vette's Avatar
72LS1Vette
There are always plenty of things to worry about when you own a C3.
The frame rust doesn't look bad. Feel inside the holes with a finger to see if there is much scale inside the frame. If there is, worry more. The body mounts look shot and sometimes you will find a mount rusted out when you take the rubber off. Those dangling wires used to connect to something. Get a wiring diagram and figure out if they are original or put in afterwards.
Rick B.
Old Mar 10, 2007 | 11:22 PM
kdf1986's Avatar
kdf1986
It doesnt really look that bad from the photos. Just a lot of surface rust. I would think that many of our cars have similar looking chassis.
kdf
Old Mar 10, 2007 | 11:26 PM
SIXFOOTER's Avatar
SIXFOOTER
Mine looked a lot like that when I started on it, good thing is the oil leaks stop a lot of rust, LOL
Doesn't look bad, clean it up, replace the mounts and paint everything you can get to under there
To anything here to worry about?
