1969 seatbelt replacement
Old Mar 10, 2007 | 10:25 PM
Shoevette's Avatar
Shoevette
Default 1969 seatbelt replacement
I need to replace the passenger side seatbelt in my '69 (lap only). The prior owner was nice enough to pass along a new piece when I bought the car. The driver side was already in, but the passenger side is frozen in one position, so it is basically useless (frozen in a position where only a skinny, vertically challenged person -- gotta be PC -- can fit in it).
Now, I got the trim out around the door and peeled the carpet back. I can't see where I bolt in on the door side. I looked under the car and see a bolt/nut with some washers and am guessing they are the anchor. I have the Chilton's book, but it is useless.
Can anyone guide me through this? Do I have to pull the seat??
Thanks...Mark
Old Mar 10, 2007 | 10:45 PM
FrankVincent's Avatar
FrankVincent
Account disabled by user request 5 Jan 09
If you have the 1969 AIM (assembly manual), it is pictured under UPC1, F26
Old Mar 11, 2007 | 12:00 AM
halfmoontrail's Avatar
halfmoontrail
Thanks...Mark
Mark, you have to pull the seat, pull back the carpet, in the midle of the floor board a few inches in front of the rear bulkhead. Almost always very rusty, hit with PB blaster for a few days before tyring to loosen.
Steve
Old Mar 11, 2007 | 12:28 AM
rihwoods's Avatar
rihwoods
This is from my 69 AIM...I did mine without taking seat out...but it was a pita leaving trim/threading belt thru...
Rich
Old Mar 11, 2007 | 08:13 AM
Chuck Gongloff's Avatar
Chuck Gongloff
Active Streak: 90 Days
For 1969, the "door side" seat belts mount under the center of the seat, so the seat has to come out to get to the bolt.
The belt is mounted under the seat. It then heads rearward and outward, and runs under a metal plate, which is under the carpet.
The belt then comes through a slit in the carpet. That slit has a large plastic/rubber grommet. Chuck
Old Mar 11, 2007 | 11:13 AM
Shoevette's Avatar
Shoevette
Rich -- thanks so much for the page from the assembly manual -- exactly what I needed. It is certainly more of a project than I had imagined when I said to myself yesterday, "Think I'll slap that seatbelt in today."
Old Mar 11, 2007 | 11:56 AM
rihwoods's Avatar
rihwoods
Your welcome...and Chuck is correct...I did mine the hard way...threading belt thru with heavy fishing line.....
Rich
To 1969 seatbelt replacement
