Adding Shoulder Harnesses to a '75 Vert?
Old Mar 12, 2007 | 03:32 PM
INFERNO Z07's Avatar
INFERNO Z07
Default Adding Shoulder Harnesses to a '75 Vert?
Hi, I 'think' that I want to add the shoulder harnesses to my '75. My rear quarter trim panels appear to have the cut-outs for them. Questions if anyone can help: what would it take to do the conversion - seat back area where the belt comes through, anyone make aftermarket shoulder assys that 'bolt into' the rear, any other thoughts or photos of some existing shoulder assy's so I can see what I'm up against? My lap belts do have the '****' that the lap belt would latch on to.
Thanks! Roger
Old Mar 12, 2007 | 03:41 PM
rihwoods's Avatar
rihwoods
http://www.andoauto.com/Corvette1.htm
My 69...
Rich
Old Mar 12, 2007 | 09:12 PM
INFERNO Z07
Thanks Rich! If I can't find the parts to do the factory shoulder belts I'll use this option. I see that I can get the seat inserts with the belt pass-through area from several suppliers, I just haven't located the actual shoulder belts yet. Need Black ones so should be easiest of the colors at least
Roger.
Old Mar 12, 2007 | 09:43 PM
Posi_trac_tion's Avatar
Posi_trac_tion
Cruising
Default Link to great seatbelt forum post
This should help: http://forums.corvetteforum.com/show...maro+seatbelts
Old Mar 12, 2007 | 10:13 PM
rihwoods's Avatar
rihwoods
Roger.
Your welcome...just watch capatibility across shoulder/lap belts...for example my stock GM lap belts were not compatible with Andover shoulder belts...so I bought a complete set..
Good luck on your search..
Rich
To Adding Shoulder Harnesses to a '75 Vert?
