U-joint?
Old Mar 12, 2007 | 04:20 PM
Skyhigh82's Avatar
Skyhigh82
Default U-joint?
Any reason to buy from a vette vendor or is the local auto parts fine?
Need to replace mine on my half shafts.
Old Mar 12, 2007 | 04:34 PM
GD70's Avatar
GD70
Auto Zone, NAPA should do it.
Old Mar 12, 2007 | 04:38 PM
GTR1999's Avatar
GTR1999
I use Spicers and most of the suppliers here do not carry the zerkless ones. I don't care for the cheaper common joints- had them fail. Do it right, spend the extra $10 per joint and get a better one.
This post will help you
http://forums.corvetteforum.com/show....php?t=1548292
genuine1980's Avatar
genuine1980
I get them from a local parts store...
When I got mine, I got the kind with the grease nipple on them. I was told by ppl on this forum that the kind I got are weaker, and that I should have gotten the solid kind without the grease nipple. I don't know if local parts stores have these solid kind.
I've had the grease nipple type on my car for a few years now with no problems... and I have a motor pushing 530hp. However... I do have safety loops on the half shafts, for the just in case.
Old Mar 12, 2007 | 06:08 PM
bluthundr's Avatar
bluthundr
If you use the greaseable ones and actually grease them once in a while like most people don't, they will be fine in a street car. If you are taking it to a drag strip, go with the solid spicers.
Old Mar 12, 2007 | 06:31 PM
rihwoods's Avatar
rihwoods
With zerk....$9.99 + tax at Kragren's...they don't come fully lubed...you must lube at installation....MADE IN JAPAN>>
Old Mar 12, 2007 | 08:55 PM
Artsvette73's Avatar
Artsvette73
Any Vette vendor would be happy to fill your order. After the buy them from their local auto parts store.
Old Mar 12, 2007 | 09:08 PM
Ironcross's Avatar
Ironcross
Vendors are perfect if you want to pay double or more for the same thing. I suspect all they see in us is $$$$$ and dumb customers.
Old Mar 12, 2007 | 09:14 PM
ratflinger's Avatar
ratflinger
NCM Grand Opening Veteran
St. Jude Donor '11, '17
Spicers are great, but a PITA to install. The plastic seals break very easily (even when installed by professionals). Neapco might be better. stay away from zerks.
Old Mar 12, 2007 | 11:10 PM
70vert's Avatar
70vert
Banned Scam/Spammer
Be carefull with those 1/2 shaft flanges.
Old Mar 12, 2007 | 11:29 PM
b71vette's Avatar
b71vette
Call a local Commercial Truck Repair Shop and get a recommendation on the best driveline shop in town. Take the half-shafts off the car and have the driveline shop do the labor. I recommend the Spicer Life u-joints. I was able to save $10 per U-joint vs. buying from the Vette Vendors.
They also have the equipment and skills to avoid bending the flanges.
Old Mar 13, 2007 | 01:31 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Neapco joints are available at AutoZone.
To U-joint?
