Car on jackstands
Old Mar 12, 2007 | 08:02 PM
bruced267's Avatar
bruced267
Default Car on jackstands
Am I doing any damage by letting the car sit like this, and or jacking it up? Seems to make some unhappy noises! and pass side didnt want to open to easily.
Old Mar 12, 2007 | 08:17 PM
Retro78's Avatar
Retro78
Need some more background.. where have you placed the stands?
Old Mar 12, 2007 | 09:10 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Sounds like you have a weak frame. Mine's been on jackstands for eight months, and it hasn't "tweaked" at all. Radiator support is out, too.
Old Mar 12, 2007 | 09:16 PM
bruced267's Avatar
bruced267
I know the frame is not weak. Jack stands are placed in front of rear tire where frame goes up, behind front tire right where frame curves in.
Old Mar 12, 2007 | 09:23 PM
Georgia1974's Avatar
Georgia1974
Your jackstands seem like they are placed OK. But do you have both sides driver and passenger on stands for balance ? I always open the doors a little and unlock the t-tops when I put in on jackstands. just in case.
Old Mar 12, 2007 | 09:24 PM
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
We all have weak frames
Old Mar 12, 2007 | 09:27 PM
bruced267's Avatar
bruced267
Yup both sides are up, and thats how I found out the pass side door was a little tweaked.
SILVERSIXX's Avatar
SILVERSIXX
Old Mar 12, 2007 | 09:29 PM
SmokinBBC's Avatar
SmokinBBC
When I have the car up on stands for any length of time, I remove the rear tires and jack up the trailing arms an put jack stands under them. I have the car up on stands for long periods without any problems.
Old Mar 13, 2007 | 01:34 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
My stands are in the same place, the car has been on them for eight months with the doors closed and t-tops on. All four still operate fine. Obviously, your car is flexing more than mine.
Only going to matter if you have other conditions that need repair.
Speak for yourself.
Old Mar 13, 2007 | 08:41 AM
71rdster's Avatar
71rdster
The frames are not necessarily weak, but they do flex as they were engineered too. They weren't engineered for sitting on jack stands though, they were engineered to be sitting on 4 wheels.
Old Mar 13, 2007 | 09:57 AM
81' Corvette Guy's Avatar
81' Corvette Guy
Any time the car is jacked up...from a corner, side or until it is supported properly on all 4 corners. I know when I have had work or tires checked/changed, I loosen up the t top locks, crack the hood and crack the doors. I have seen someone that did not do this and broke a t top as the frame flexed. Just my 2 cents..
Old Mar 13, 2007 | 12:23 PM
Bob Onit's Avatar
Bob Onit
My owners manual says to remove the T tops before jacking the car up.
Old Mar 13, 2007 | 07:36 PM
SmokinBBC's Avatar
SmokinBBC
Damn, I missed that one!
Old Mar 13, 2007 | 09:05 PM
Bob Onit's Avatar
Bob Onit
No big deal...probably doesnt really matter
Old Mar 14, 2007 | 11:34 AM
427-390's Avatar
427-390
Missed that one too! I'm sure that back in the day when these cars were built, if it was raining or snowing, you would remove the t-tops if you had to change a flat tire, yeah, right.
I never have had a problem with the body flexing when jacking my car up. I carefully center my jack on either the front crossmember, or underneath the differential to lift the car.
Old Mar 14, 2007 | 11:57 AM
Bob Onit's Avatar
Bob Onit
Just posting what the General had to say in my owners manual....
To Car on jackstands
