New Battery for Spring - Suggestions?
Old Mar 12, 2007 | 08:46 PM
Mick42767's Avatar
Mick42767
Default New Battery for Spring - Suggestions?
Going to get a new battery this week for my 72 SB coupe. Any suggestions? Don't care about originality, just want a nice strong battery that easily goes a week or 2 between starts. Thanks, Mick
Old Mar 12, 2007 | 09:14 PM
gq82's Avatar
gq82
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Most will probably say get an optima red top....I like to stay close to GM originality so I chose an ACDelco 6yr. Great battery, holds a charge for a very very long time.
I would also get a battery charger to keep it fresh.
Old Mar 12, 2007 | 09:23 PM
Durango_Boy's Avatar
Durango_Boy
Yellow Optima for me. It was on a shelf for six months and still held a 13V charge.
Old Mar 12, 2007 | 09:30 PM
rihwoods's Avatar
rihwoods
Yep..been using them since I've owned the 78 (28 years)..Never a problem...and I don't charge the things..today,I started the 78 after two weeks sitting...spun that motor like crazy...
Cranks the 69 502 really good,as well...
Rich
Old Mar 12, 2007 | 09:32 PM
68 NJConv 454's Avatar
68 NJConv 454
I run the optima redtop, got a good deal at Costco a year ago.
Durango, whats the gizmo you got there? that power your sound system? I like the tie into the batter terminal, much cleaner then an eye hoop. where'd you get it?
Old Mar 12, 2007 | 09:39 PM
Durango_Boy
It's just a set of after market battery terminals that have the built in voltage meter. Very handy for knowing what your battery has for a charge. Don't worry, the LCD readout does turn off after a few minutes of no change. If you enact a large draw on the system it will light up and show you what the current reading is. When driving it's always on. when off, it's always off.
I'm pretty sure I found them on Ebay a year ago or so, and I did like the look so I bought the set.
Big2Bird's Avatar
Big2Bird
There are basically three manufacturers. I like Delco. Don't be fooled by high CCA. They have more/thinner plates. You do not need that. Get a stock/lower CCA. They last longer.
To New Battery for Spring - Suggestions?
