Headlight kit
Old Mar 12, 2007 | 11:20 PM
Prestige593's Avatar
Prestige593
Default Headlight kit
Has anyone seen or used this headlight set up? What would be the downside to this kit?
http://cgi.ebay.com/ebaymotors/ws/eB...9014167&rd=1,1
Old Mar 12, 2007 | 11:25 PM
hdman1962's Avatar
hdman1962
Durango Boy had a post about this a while back every one seemed to think they were the only downside is they are not free
Old Mar 13, 2007 | 01:27 AM
Marcusk408's Avatar
Marcusk408
Here's a link to the post about these halos.
http://forums.corvetteforum.com/show....php?t=1609190
Old Mar 13, 2007 | 02:36 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Downside? Nothing, really. However, I personally prefer Hella lights.
Old Mar 13, 2007 | 03:08 AM
Marcusk408's Avatar
Marcusk408
There's a downside. It takes a lot of modifications to the headlight assemblies to get these darn halo headlights to fit properly. There's a lot of cutting and grinding involved. I had to enlarge the holes (4 of them) in the headlight assemblies where the bulbs stick through. What a p.i.t.a.! Then I had to cut notches in each headlight cup/bucket for the three tabs in each headlight to fit properly and a hole for the little blue bulb in the headlights to stick through. You can see the little bulbs at the bottom of the headlights. They're just for show. Also, the headlight rings will need longer screws to mount the halos to the headlight cup/bucket because the halos are thicker than stock lights. I'm still not done installing the halos. I've spent about $164 just on accessories (wires, relays, connectors, switch) to install these lights. I'm going to continue the work this weekend and hopefully finish it. If I knew what was involved I wouldn't have bought these lights. I have an '82 vette by the way and it may be easier to install these lights on other years. Who knows? I think Durango_boy had an easier time at it since his vette is a '77 I think.
Old Mar 14, 2007 | 11:39 AM
Prestige593
Marcusk408, Is this the same kit that you bought? Do you have pics? I am a little put off now that you say its a PITA.
Old Mar 14, 2007 | 11:07 PM
Marcusk408's Avatar
Marcusk408
I bought my halos from another seller on Ebay. I think they're from a different maker then the ones you saw but identical in dimensions. I wish Durango_boy had a picture of the rear of his halos to confirm this. His and mine appear to be Chinese made products. There's no writing/stamp anywhere on these headlights. No "DOT Approved" or anything like that.
Click on pics to enlarge...
Rear of halo against headlight assembly. Hole needs to be enlarged for halo to fit through.
Rear of headlight cup/bucket. Diamond shape needs to be enlarged for halo to fit through and front of cup needs three notches cut into it for the three tabs in back of the halo to sit in.
Close up of halo headlight.
Rear of halo headlight.
Old Mar 15, 2007 | 12:18 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
I prefer the E-code Hella lenses. No one in Missouri gives a darn anymore...they removed the headlight aimer test from the safety inspections years ago...so we don't need the DOT lugs. No one has ever failed my cars for having "off-road only" lights.
Old Mar 15, 2007 | 07:28 PM
Prestige593
I think it looks cool, but I have so much other work on this project that I think I'm going to have to wait. I want to get the car on the road before I start ANOTHER project.......
I am in way over my head, and the credit cards are buring up........
Marcusk408 post pics when you are done. I saw Durango's pics and they look awsome.
Old Mar 15, 2007 | 10:14 PM
Marcusk408's Avatar
Marcusk408
I will definitely post pics.
To Headlight kit
