Nose fiberglass separation
Old Mar 13, 2007 | 06:54 PM
bluthundr's Avatar
bluthundr
Default Nose fiberglass separation
The fiberglass of the nose is separating from its steel reinforcing counterpart in my 76.
Here are a couple pictures.
http://i18.tinypic.com/4d1zng0.jpg
http://i13.tinypic.com/3zjc4ya.jpg
This is causing the nose not to align properly with the hood. I would like to fix this while I have it torn down, but not sure how to do so. My thought is to get some strong construction epoxy, lay a bead in-between there, and clamp it back together. Any suggestions?
Old Mar 13, 2007 | 07:38 PM
wacked's Avatar
wacked
From: If the world didnt suck, we would all fall off. Troy,Ohio.
Cruise-In VI Veteran
St. Jude Donor '04-'05-'06-'07-'08
What you just said.
Old Mar 13, 2007 | 08:59 PM
72LS1Vette's Avatar
72LS1Vette
You would be better off spending some more time and doing a better fix. If you remove the support you can rustproof it on both sides and then bond it back onto the nose. I don't remember the name of the adhesive offhand but if you do a search on "bonding" you will probably find it.
Rick B.
Old Mar 13, 2007 | 09:08 PM
Roscoe's Avatar
Roscoe
IT
Old Mar 13, 2007 | 09:41 PM
SIXFOOTER's Avatar
SIXFOOTER
Better to fix it right. Remove the headlight assemblies, finish removing the header bar. Clean off the old adhesive, you will have to do this with a chisel and hammer.
Clean and paint the header bar if its not to rusted, replace if it is.
Use Fusor or 3M Panel Adhesive to reattach the header bar to the surround with clamps.
Reassemble
To Nose fiberglass separation
