The pass side #4 anchor nut twists in the retainer. Its not a problem to cut the bolt to remove the body, but that still leaves me the issue of a siezed nut in the body. Any suggestions other than removing the metal mount rivets? Thanks in advance
I just did this on a 77 car 2 weeks ago. 7 of the 8 body mount bolts came right out with no problem. Did not even have to use my PB Blaster. But the passenger side #4 spun the nut inside the cage.
Intersesting that when I removed the interior, the PO had stuffed a rag down in that hole and the rag was rust stained when I pulled it out. Didn't think much about it till I removed the body mount bolts.
I tried the wedging the screwdriver trick but I ended up cutting the cage off with a Dremel (using a mirror). As I was cutting and prying on the cage, it popped off the rivets. I put a large endwrench on the now exposed nut, sprayed with PB Blaster and tried to turn the bolt against the wedged endwrench (No one around to help that day). I began to hear glass splitting so I stopped, got the smoke wrench out and cut the head off the bolt and it came right out.
I used a saws-all to cut the bolt between the body and the mount. It cut the bolt and the heads of the rivets off. Once I got the rubber cushions out of the way, I hit what was left of the bolt with a punch and the nut and cage pop up into the interior.
