exaust too unrestrictave?
Old Mar 20, 2007 | 10:19 PM
randommj's Avatar
randommj
Default exaust too unrestrictave?
can exaust be too unrestrictave? someone told me that sweet thunder is for bigger engines than the 350, ive got some but they arent on yet, could this be bad?
randommj
Old Mar 20, 2007 | 10:37 PM
randommj's Avatar
randommj
i got the awnser, so dont worry bout it
thread still open for discussion for anyone intrested
randommj
Old Mar 20, 2007 | 11:02 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
No.
JIM
Old Mar 21, 2007 | 02:40 AM
standup's Avatar
standup
randommj
So what was the answer ?????
I don't know what sweet thunder is, but I recently swapped from factory style side pipes to undercar exhaust on a 9.3:1 compression 350.....I've had the side pipes on for 2 years and didn't re-tune anything, but I think the car ran and idled better with the more restrictive undercar exhaust.......
Open for discussion.....
Old Mar 21, 2007 | 07:26 AM
Ganey's Avatar
Ganey
The less restrictive the better. The undercar should be less restrictive than the sidepipes!
Old Mar 21, 2007 | 08:03 AM
MN80Vette's Avatar
MN80Vette
An exhaust system can only be too restrictive if the low restriction causes other problems. In my case, the drop in restriction from adding full length ceramic Dynomax headers and custom-bent pipes (breath-out) created a breath-in problem.
The jets in my Holley carb were not big enough to handle the increased airflow through the carb resulting from the new exhaust. New jets required and "bigger" accelerator pump fixed that problem.
Old Mar 21, 2007 | 11:12 AM
Big2Bird's Avatar
Big2Bird
Originally Posted by 427Hotrod
No.
JIM
Old Mar 21, 2007 | 11:21 AM
randommj's Avatar
randommj
i sent someone a PM and a few days later made the thread and right after i made this thread he sent me one back, same thing you guys are saying ,how are the side pipes more restricted then the underbody exaust?
randommj
Old Mar 21, 2007 | 11:32 AM
GD70's Avatar
GD70
I posted a thread a while back - (2" vs.2 1/2" exhaust), and the general consensus was mixed. Some said 2" ran better with a bit of back pressure and not to waste my time with 2 1/2", wouldn't notice much performance gain. Others said a less restrictive exhaust would be better, which makes sence. I'm using stock manifolds, intake & Q-Jet. Jury's still out as far as I'm concerned. I'll need to replace my exhaust this spring/summer, so I'd also like to get more opinions on this.
Glenn
Old Mar 21, 2007 | 11:42 AM
randommj's Avatar
randommj
well im going to 4 inch pipe with 2.5 inch mufflers, i hope everything works out ok
randommj
Old Mar 21, 2007 | 12:00 PM
Big2Bird's Avatar
Big2Bird
randommj
Some guys posted Dyno results comparing sidepipes and straight back exhaust. Ths sidepipes showed a reduction in HP.
Old Mar 21, 2007 | 12:03 PM
randommj's Avatar
randommj
wow i thought it would hav been the other way arround, shorter pipes and all hmmm
Miles
Old Mar 21, 2007 | 12:06 PM
Big2Bird's Avatar
Big2Bird
Miles
Dyno's don't lie. It may be the added turns in the pipes. Who know's. Maybe someone will expound on this one.
Old Mar 21, 2007 | 12:16 PM
gkz's Avatar
gkz
I remember that years ago, Corvette exhaust manifolds were coveted. After looking in vendor's catalogs, the earlier SB had 2.5", and 65> had 2". Horsepower ratings during both periods were pretty good (high) measured at the flywheel. Are the results in this thread using factory manifolds or headers before the exhaust systems?
Old Mar 21, 2007 | 12:25 PM
Big2Bird's Avatar
Big2Bird
I believe it was headers. I am not positive though. I have enough of a hard time remebering to take my Geritol.
Old Mar 21, 2007 | 10:01 PM
chris73cpe's Avatar
chris73cpe
Miles
From what I've heard it was only the factory style sidepipes that were more restrictive. The aftermarket stuff like hooker is usually 3 or 4" pipe.
Old Mar 21, 2007 | 10:04 PM
Durango_Boy's Avatar
Durango_Boy
Side pipes CAN be more restrictive, and those dyno results were recorded at very high RPMs. At normal driving speeds and RPMs the two are almost equal. When you really let the motor scream is when there is a difference, and it's marginal at that. Unless you're watching your track times, and need every tenth you can get...stick with straight. If you're a cruiser...you will never notice.
To exaust too unrestrictave?
Old Mar 21, 2007 | 10:08 PM
BSiegPaint's Avatar
BSiegPaint
St. Jude Donor '06-'07
The factory pipes are VERY restrictive with their reverse flow design. If you cut one open you will see the inner chambers are very small. Switching to an aftermarket side pipe (i.e.Hooker) results in a huge gain in air flow.
Old Mar 21, 2007 | 10:54 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
My understanding is the hooker 1 7/8 port side pipe headers are equal length primaries into a 4" and the best flowing exhaust available depending on the inserts used. The max flows also advertise a 23HP increase over open headers??? How does that work?
Old Mar 21, 2007 | 11:08 PM
427Hotrod's Avatar
427Hotrod
2.5" is pretty decent up to the 500-550 hp range....but I would use 3' if I was starting from scratch. Uncapping my old 427 with 2.5" pipes and Flowmasters showed very little improvement. it was running low 11's@123.
A fellow I know just replaced a full 2" system on a '61 283/270 car with a full 2.5" including manifolds along with the *off road* mufflers. no back up dyno tests yet...but seat of the pants difference is very impressive.
Factory sidepipes are very restrictive. The mufflers neck down to like 1.5'-1-3/4" internally. The Hookers are Ok if you completely remove the mufflers. On the big blocks the Hooker mufflers are racking up almost a 100 RWHP loss on 500+ Hp motors.
If you install some decent mufflers on them they are fine....but those 4" pipes are pretty small internally.
Under light throttle none of it really matters much. It only takes a few HP to drive down the road..but when you put your foot in it....you better have good stuff!!
What gets confused as having better performance with pipes capped up is often better scavenging happening in the rpm range you're dealing with with the long exhaust pipes. My 540 was up 40 ft lbs at some very low points on the chassis dyno when capped up with Flowmasters...but was down over 50 RWHP as RPM climbed!!
JIM
