69 to 77 FRAME QUESTION
Old Mar 20, 2007 | 10:39 PM
n.g.hayes's Avatar
n.g.hayes
Default 69 to 77 FRAME QUESTION
Found a frame listed for a 74 to 77. Ad info states with minor modifications, will work for 69 to 73. I am sure the rear crossmember would be different but what other changes would need to be made. Not sure what all would be involved to make it fit a 71 but sure sounds interesting. Any thoughts from the frame experts?
Thanks,
Norm
Old Mar 20, 2007 | 10:50 PM
BackN70's Avatar
BackN70
If you have a 71, you should know that manual and auto frames have crossmembers that are different. The manual is welded in and the auto is bolted in. 68-72 frame is what I would look for. The 73 frame had a different frame exentsion on the front and would have to be modified to work for the 68-72.74 and up would need modifications to the front and rear of the frame.
parkerracing's Avatar
parkerracing
Everything you need to know is listed here http://www.71corvette.com/frames.html As long as you don't mind originality (and alittle work) 63-82 fit. /:\
Old Mar 20, 2007 | 10:57 PM
parkerracing
If you drive the car (and I mean DRIVE the car) the removable crossmember is soooo much nicer to service the trans/clutch.
Old Mar 20, 2007 | 11:03 PM
n.g.hayes's Avatar
n.g.hayes
Your location looks familiar, I bet you have a frame for sale!!
Old Mar 20, 2007 | 11:08 PM
parkerracing
Right you are! I'm glad to see that folks look at that stuff so soon after it's listed. If you have any other questions, just ask. /:\
BTW, the auto crossmember thing is an old racers trick from back in the day.
BTW pt II. I didn't write the frame artical on the '71 registry site if you are looking for unbiased info.
Old Mar 20, 2007 | 11:28 PM
wacked's Avatar
wacked
From: If the world didnt suck, we would all fall off. Troy,Ohio.
Cruise-In VI Veteran
St. Jude Donor '04-'05-'06-'07-'08
Whats crazy is a 1977 frame can sell for $3000+. I would look in to a new tubleler frame
Old Mar 21, 2007 | 12:43 PM
72LS1Vette's Avatar
72LS1Vette
The repro frames are starting to look more reasonably priced all the time. If I had an offer of $4,000 for the 73 frame that I'm cleaning up now I'd probably sell it and get a Rowley Corvette frame.
Rick B.
Old Mar 22, 2007 | 07:50 AM
parkerracing
The body that was going to go on the frame has met it's reserve, so now I would like the frame to find a new home too. I'd be happy to see it go in the $1500-2k range. If you guys know anybody paying 3-4 grand for one of these, please send 'em my way. /:\
To 69 to 77 FRAME QUESTION
