light problem
Old Mar 23, 2007 | 01:42 AM
bsenne's Avatar
bsenne
1st Gear
Default light problem
I have an 82 corvette and I have to pull the lights to get them to come up, they go down by themselves fine. What could be the problem
Old Mar 23, 2007 | 06:30 AM
crazywelder's Avatar
crazywelder
Since they work (kind of) one or both of the headlight actuators might have a vacuum leak. If you have a hand vacuum pump, you can diagnose the actuators by connecting a hose to the vacuum port on the bottom of the headlight actuator (the bottom port opens the headlamps, the top port closes the headlamp) and see if you can pump each headlamp open manually. If you can't open them with vacuum, the actuator shaft seal is probably worn out and leaking. The seal costs about $10 at the Vette parts distributors. A lot cheaper than buying new actuators. Just be carefull disassembling the retainer that holds the seal in place, the tabs that are bent over are fragile. Good luck.
