SS line replacement
Old Mar 31, 2007 | 05:01 PM
JustForFun's Avatar
JustForFun
Default SS line replacement
IM thinking of adding SS fuel and brake lines to my frame off. The lines i have arent in bad shape, but i was thinking since im at this point might not be a bad investment. How do they ship such long lines? Anyone had success with getting them in decent shape? Ive seen a few phots from couple of vendors and they seem to be folded up....Is this the way they ship? If so any tips on bending them back straight....and do they come out decent after such?
Old Mar 31, 2007 | 05:28 PM
ShinodaVette's Avatar
ShinodaVette
They bend the lines and stuff them in boxes to ship them. Usually a big radius bend about mid way for fuel lines. I got my SS 3/8" fuel line from Ecklers and that's how it was packed. They put a couple of bends in it to get it in the box. One about mid way, then on the end where it shoots over from the frame to the fuel sender. I still haven't gotten its shape to match the factory lines but hopefully somebody else will post what they have done. The 3/8" SS line is a bear to bend; even with a bender.
Old Mar 31, 2007 | 05:41 PM
wabco40's Avatar
wabco40
I had ss brake lines air freighted down to Australia. they came in a large box with the rear line having a large radius shipping bend about half way. The rear line straightened out and all lines fitted well.
Old Mar 31, 2007 | 10:45 PM
The3's Avatar
The3
Originally Posted by JustForFun
IM thinking of adding SS fuel and brake lines to my frame off. The lines i have arent in bad shape, but i was thinking since im at this point might not be a bad investment...
Yes, a good investment with litte work required. I just finished installing a new suspension, engine, and brakes and wish I would have replaced the brake lines while it was all apart. I'm replacing the lines now and it's a pain in the rear.
Old Mar 31, 2007 | 11:10 PM
noonie's Avatar
noonie
Why don't you just buy the annealed ss tubing locally and do it yourself. If your doing a frame off, then this could be part of the experience.
Old Apr 1, 2007 | 03:27 PM
eastltd's Avatar
eastltd
I bought the full SS brake line kit from Zip. All the lines were marked showing where the shipping bend was located. I just hand straightened at those points and installed. Easy.
I still need the fuel lines and will order them also from Zip. Good service and reasonable pricing. The fuel lines are $75 each tank to pump.
Old Apr 1, 2007 | 04:01 PM
1ARACE's Avatar
1ARACE
I just finished doing this last week myself, seems there is one main supplier for them because they all have the bends in same place and tagged accordingly, usually come in oversized box, mine came in 2 (one inside another).
The 'prebend', I found out, is not, always 'prebent' exactly correct in all spots and you may have to wrestle with it a bit. I fought like hell with the rear lines, especially the rear one coming out of the caliper and running along the T/A.
Also had trouble at the main brake junction block, at the front...seems some may be bit short or long...but not always exact, and was hard to get them all connected and then bolting it to frame (tried with it bolted to frame first time, that didn't work well).
Overall it's a real PIA, I'd really consider how bad they really are...if it's just surface rust not a big deal (clean them up a bit), if serious corosion then yeah, but long as insides are clean you should be good.
Just my 2 cents.
Old Apr 1, 2007 | 04:11 PM
ShinodaVette
Just my 2 cents.
Glad to hear I'm not the only one having trouble with my "pre-bent" lines not being exactly bent where they should be. The problem is seriously multiplied when you start talking about a 3/8" SS fuel line. The bigger lines just don't bend well by hand and the bender isn't helping much.
Old Apr 1, 2007 | 04:48 PM
jimiscnc's Avatar
jimiscnc
Default annealed ss tube locally??
what's the specs and what sort of supplier might have the correct ss tubing? (mcmaster carr supply can do it website/mail order, I think? they have EVERYTHING)
Also, isn't there a problem doing the double bend required of the flair that work hardens and cracks the ss?
Just asking, I want to bend my own, also.
thanks
-85% Jimmy
Old Apr 2, 2007 | 12:06 PM
68/70Vette's Avatar
68/70Vette
Yes, the SS brake lines come bent in the shape of a big "U." To straighten them up....
I have a concrete patio and the concrete has an straight crease trowled into it. I lay a flat side of the ss brake line "U" into the crease. Have someone hold it tight. Now just walk the bent part of the U into the crease. When you get finished you'll have a pretty straight piece of tubing. I straightend out some cunifer (copper alloy) gas line this week end using the same technique.
About double flares in ss. As far as I know, you have to have a hydraulic tube flarer to get enough pressure to double flare ss. Eastwoods sells one for about $500. Inline Tube in the past has advertised that if you send them a brake line, they will scan it and duplicate it in SS. This gives you the option of fabricating your lines in copper (easy to shape and double flare) send it to them, and they will duplicate it in SS. I used this service for some custom brake lines along my trailing arms to my SSBC aluminum calipers. This was a simple job for them and they charged a minimal price.
Old Apr 2, 2007 | 12:56 PM
Red 69's Avatar
Red 69
You should be aware that seating the s/s brake lines can be a challenge. They were a struggle on my 69; be sure you have a quality set of flare nut wrenches or the difficulty will increase exponentially. As many have said, the tubes come bent and shipped in a box and can be easily straightened.
Old Apr 2, 2007 | 01:16 PM
Twin_Turbo's Avatar
Twin_Turbo
double flaring is ONLY needed on NON seamless tubing, if you have seamless high quality tubing you won't need a double flare. You need a quality flaring tool to do single flares in stainless, you need a 900+ $ flaring tool to do proper double flares in stainless without destroying the flare cone. Also, don't use a tubing cutter to cut the lines, it'll work harden the tubing and make it even harder to flare. I use a cut off wheel and then use the clamping dies as a guide and carefully file the end flat, then you can make a perfect flare (I only use 37deg. double flares though backed up w/ tube sleeves)
Old Apr 2, 2007 | 02:12 PM
chevy69's Avatar
chevy69
St. Jude Donor '08
Got all my stuff from zip. Replaced brake and fuel lines with SS. As mentioned above the big bend in the lines put there for shipping were easily straightened by hand. My son and I did the job in aboout an hour on my frame. Obviously the body (as required) was already off. I was very happy with the fit of the bends on mine.
To SS line replacement
