leakdown test..am I doing something wrong?
Old Apr 1, 2007 | 01:24 PM
chris73cpe's Avatar
chris73cpe
Default leakdown test..am I doing something wrong?
I just picked up a leakdown tester from harbor freight that has the 0-100psi guage on one side and a percentage loss guage on the other. the thing is when I try to use it the loss guage is always pegged at way below zero unless I back the pressure off to around 15 psi. I can hear air flowing through, so it should read something over zero. I don't see any other adjustments on the guage for calibration other than the regulator either. Am I doing something wrong here or is it just a crappy guage?
Old Apr 1, 2007 | 01:45 PM
RMS73's Avatar
RMS73
the instructions for my unit says:
Postion cylinder at TDC
Turn the regulator **** fully counter-clockwise. then connect shop air, 45-150 to the regulator w/o cylinder hose connected. turn reulator clockwise until leak gage reads zero at the right end of the gage.
Screw cylinder hose into spark plug hole and then connect hose plug end into quickcoupler of tester block. The amount of leakage will now show on the leak gage as a % loss.
Roger
Old Apr 1, 2007 | 04:34 PM
chris73cpe's Avatar
chris73cpe
yeah, that's what I tried but the guage reads 0 at 15psi and is well past the mark at anything over. Everything I've seen says it should be more like 100psi, or at least over 50.
Old Apr 1, 2007 | 05:28 PM
RMS73's Avatar
RMS73
Just hooked my tester up on the work bench. The pressure gage read 35 psig when the leak gage read 0%.
Roger
Old Apr 1, 2007 | 05:30 PM
Big2Bird's Avatar
Big2Bird
Are you sure the valves are closed. Are you on compression?
Old Apr 1, 2007 | 08:20 PM
chris73cpe's Avatar
chris73cpe
I have the distributer cap and valve covers off, so I know I'm at least close to the top of the compression stroke. It's setting the guage before I even hook it up to the engine that doesn't seem right. It seems like the second guage is just very badly calibrated with no way to adjust it.
Old Apr 1, 2007 | 08:24 PM
Topless75's Avatar
Topless75
Key words: Harbor Freight...
Old Apr 1, 2007 | 08:31 PM
chris73cpe's Avatar
chris73cpe
I would not be surprised at all if that was the problem, but I did do a little searching around the net and got the impression that this guage was at least usable for what it was. Maybe I can go to grainger and pick up a bette pressure guage to replace the %loss guage with something I can adjust.
Old Apr 1, 2007 | 08:39 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
i like harbor freight.......and i am unaplogetic about it!
Old Apr 1, 2007 | 10:07 PM
Big2Bird's Avatar
Big2Bird
Harbor Freight has some good stuff. They also have some crap.
Topless75's Avatar
Topless75
Harbor Freight is great for some stuff. Their "static" tools are acceptable (wrenches, hammers, rulers, etc.). Anything with a guage or motor, however =
Old Apr 1, 2007 | 10:21 PM
RMS73's Avatar
RMS73
I believe the % loss is just a pressure gage, but but a dial label showning precentage loss atarting at the max pressure reading of the gage. For you your %loss gage is probably a 0-15 psi gage. As the air flows out of the cylinder you lose prssure due to the air flow. The only difference between a 0-15 and a 0-35, like mine, would be a small amount of accuracy. I would just use what you have.
Roger
To leakdown test..am I doing something wrong?
