Pedal Assembly Question
Old Apr 2, 2007 | 10:43 AM
CrossedFlags77's Avatar
CrossedFlags77
Default Pedal Assembly Question
Can a clutch/brake pedal assembly from a non-PB Vette be used on a PB Corvette?
Old Apr 2, 2007 | 11:12 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Yes.
Old Apr 2, 2007 | 11:18 AM
Corvette Engineering's Avatar
0Corvette Engineering
Former Vendor
It should work.
I think the only issue is the brake pushrod.
There are two holes on the brake pedal, an upper and a lower.
There are also two different brake light switch brackets.
The brake push rod would have to be moved to the lower hole and the brake light switch bracket modified to fit the upper hole or a new bracket obtained
To Pedal Assembly Question
