Yep, still $37...thanks! Any clues on how I can get a discount too?
Paragon gives a 15% discount on all purchases after you make an initial purchase of $500 or more. You also get the discount on the initial $500 or more purchase.
Forget the rivets. I used 3/16" stainless pop rivets on my first one.
Then a member clued me in ... USE 1/4" STAINLESS BOLTS. I chose
button heads ... came out great ... and EASY.
Use plenty of adhesive between the steel and fiberglass.
Do not rely on the rivets or bolts alone to hold it tight.
Make it "one" with the body.
I tried fitting 1/4" bolts through my new reinforcements. They didn't fit. I ended up buying a bunch of #10 stainless screws, washers, rubber washers and nylock nuts.
