71 Ground Problem
Old Apr 5, 2007 | 10:16 PM
xCCTer's Avatar
xCCTer
CF JASOC Member
From: Downtown Annapolis, MD. The Future is where we all have to live. Let's not screw it up.
Default 71 Ground Problem
I'll try to make this as short as possible.
My '71 interior lights haven't worked since I bought it. Got new door switches and replaced them. Put a new 20a fuse in and lights work. TADA!
Then...
I'm checking the wire routing before I put the kick panels back on, and feel that the wires from the switches are getting very warm. Immediately pop the fuse back out.
Remove switches and notice that the plastic part that the wire connectors plug into for the plunger to make contact with are partially melted.
I'm thinking there has to be a bad ground, but can't quite figure out where to look after being inundated with all the stuff on the wiring diagrams in the Factory Service Manual.
Anyone else ever run into this? Until I figure this out, I have no Lighter/Clock/Interior Lamps.
Thanx in advance.
Old Apr 5, 2007 | 10:30 PM
SIXFOOTER's Avatar
SIXFOOTER
Its not a bad ground, the switches furnish a ground to turn on the lights. The problem os somewhere else, there is a short somewhere, maybe the light timer, the excess current is running to ground thru the switches, thats why they are heating up.
Old Apr 5, 2007 | 10:40 PM
Big2Bird's Avatar
Big2Bird
Yep
Old Apr 5, 2007 | 10:52 PM
shoptek's Avatar
shoptek
'71's dont use a timer circuit. A 20A fuse seems too large for the circuit, for safety sake.
You might have an issue in the headlight switch.
Old Apr 5, 2007 | 10:55 PM
randommj's Avatar
randommj
I wish i could help
Miles
Old Apr 5, 2007 | 11:17 PM
CCrane65's Avatar
CCrane65
You do only have one wire running to each switch, right? The switches ground through the frame so you shouldn't have a ground wire on them.
Bubba wasn't smart enough to scrape off a little excess paint in the door jamb on my car and ran a separate ground for the switch instead. It didn't work.
cc
Old Apr 5, 2007 | 11:27 PM
xCCTer's Avatar
xCCTer
CF JASOC Member
cc
There are 2 wires.
Old Apr 6, 2007 | 12:00 AM
CCrane65's Avatar
CCrane65
Originally Posted by xccter
There are 2 wires.
If that second wire touches the plunger when the door is open then you have found your problem. That would create a dead short. The threaded nut on the switch makes the ground connection to the chassis. You should only have a hot wire coming in contact with the plunger with the door open.
cc
Old Apr 6, 2007 | 10:10 AM
shoptek's Avatar
shoptek
There are 2 wires.
Are you working on the courtesy lamp switch (in front pillar), or the rear jamb switch?
The rear should have 2 wires---alarm and door ajar. I believe the alarm relays are under the center console or up near the middle storage compartment door.
Old Apr 6, 2007 | 05:20 PM
xCCTer's Avatar
xCCTer
CF JASOC Member
Courtesy lamp switches on front jamb. Haven't messed with the door ajar switch yet since this problem presented itself.
There are 2 wires that go into the plastic piece on the switch on the driver side, and when the plunger touches them both (door open), it completes the circuit and the lights come on.
I understand that the ground should be the switch screwed into the pillar, but there are 2 wires.
Old Apr 8, 2007 | 12:22 AM
CCrane65's Avatar
CCrane65
xccter, my driver's side switch has two wires also. Without looking at the wiring diagram, I can only surmise that the switches are tied together.
I would dig out a digital volt meter and see what kind of amperage your courtesy lights are drawing. For the wires to get noticeably hot there has to be a short to ground in that curcuit somewhere.
cc
Old Apr 8, 2007 | 12:53 AM
xCCTer's Avatar
xCCTer
CF JASOC Member
I'm with you. Just have to really go over the diagrams again next time I have more than 2 minutes to myself. Thanx.
To 71 Ground Problem
