Headlight problem.Help
Old Apr 6, 2007 | 04:35 PM
breeze99's Avatar
breeze99
8th Gear
Default Headlight problem.Help
This has probably been asked a hundred times before(Tried to find it in search but couldn't) 72' Vette..Got one headlight up and doesn't want to go down..Any way to manually close it and open it??? Thanks!!!
Old Apr 6, 2007 | 08:09 PM
Tommy Samuels's Avatar
Tommy Samuels
First sheck to see that the manual actuator switch isn't pulled down.
You need to reach up fron under the car and tug on the pivot point where the actuator attaches. Sometimes the pivot moves past the center and puts the headlight a locked position. Then you can press on the headlight and it will go down.
When it's down you push against the pivot point to start it up then lift the headlight
here's the link to troubleshoot your vacuum system
http://vetteworks.tripod.com/techdocuments/Vaccum.html
Old Apr 6, 2007 | 09:46 PM
nutseynut7's Avatar
nutseynut7
Switch your hoses on the relay valves from one to the other if the light works and the other one doesnt you have a bad relay valve
To Headlight problem.Help
