Undercoating/Bedliner: Pros and Cons
Old Apr 7, 2007 | 11:54 AM
stinger12's Avatar
stinger12
Default Undercoating/Bedliner: Pros and Cons
I want to either spray undercoating or truck bedliner inside my interior to deaden vibrations and heat. The problem is, I don't know which one to use. The good thing about spraying undercoating is that if, god forbid, I get into an accident, it can be scraped off so I can refiberglass the body. If I spray truck bedliner, this stuff will be impossible to remove if I ever encounter some cracked fiberglass on my underbody. Plus, what's all the bad rap about undercoating anyways? I mean, yes, its old technology/material, but it performs to what it was intended to do. When I removed the old stuff from my interior, the fiberglass looked like it was brand new! I don't know anymore. Who out there has used undercoating in their interior? Who has used bedliner in their interior? Which one do you recommend?
Old Apr 7, 2007 | 04:08 PM
68RATVT's Avatar
68RATVT
I used Rhino lining on my lower rocker panels to avoid chips and inside my Toyota 4runner, it's a sand buggy only, so make easy to clean and sound proofed her. Actually, doing the floor boards,firewall and storage area would have been a great idea. Don't be affraid of getting it off, once a knife gets under it, it comes up in sheets...
Old Apr 7, 2007 | 06:30 PM
Shark Mann's Avatar
Shark Mann
Rhino lining or Line-X(i think). Durango Boy knows about this subject and may chime in
-Shark Mann
Old Apr 7, 2007 | 07:28 PM
Jim71Vette's Avatar
Jim71Vette
What about bed liner material in the fender wells? Seems to me it would work there better than under coating.
Old Apr 7, 2007 | 10:29 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Seems like 69MyWay used Rhino Liner or something like this on his vette. If mine would have been a body off, I would have done something like this on the bottom to quiet it some. I have thought about doing this to my truck this summer. Its bound to work as a sound deadener.
Old Apr 7, 2007 | 11:37 PM
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
Yeah on his rear deck
Old Apr 7, 2007 | 11:46 PM
tigers123's Avatar
tigers123
Default cautionary tale
Rhino lining will add a lot of weight. Especially if it is the kid they hired for the summer doing it.
Old Apr 20, 2007 | 10:32 AM
stinger12's Avatar
stinger12
bump
Old Apr 20, 2007 | 11:00 AM
TimAT's Avatar
TimAT
I don't know about the Rhino liner, but I had my truck done with Line-X. That stuff goes on at 160*, and is harder than rock. Not too sure I'd want to use that as a full undercoat on a Vette. Maybe some urethane or epoxy paint? I did shoot the bottom of a Chevelle with Imron- Looked great, but as nasty as that stuff is I'm not sure I'd do it again.
Old Apr 20, 2007 | 11:17 AM
palamesa's Avatar
palamesa
http://i120.photobucket.com/albums/o...ttdolly003.jpg
http://i120.photobucket.com/albums/o...dolly004-1.jpg
http://i120.photobucket.com/albums/o...ttdolly005.jpg
These are from member COINWASHER....www.lizardskin.com
Old Apr 20, 2007 | 11:32 AM
MixxMaster's Avatar
MixxMaster
I WAS going to use LizardSkin, but the cost was way too much. I went with a normal roll-on bedliner that is solid when dry. I applied it in the interior so far in a couple of layers, and it went great. If you use a roller with a thinner nap, it will go on even smoother, which would be great if you are going to put fat mat or something similar on top...
Old Apr 20, 2007 | 12:22 PM
palamesa's Avatar
palamesa
I'm not sure why COINWASHERS pictures are not working. If you want to see his Lizard Skin photo's, I have a thread in the Tech section called "Body Dolly Fabrication", you can see them there. Looked pretty cool to me....gp
Old Apr 20, 2007 | 12:27 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Seems to me undercoating and a heat barrier would work best and would probably be cheaper.
Old Apr 20, 2007 | 06:26 PM
stinger12's Avatar
stinger12
bump
Old Apr 20, 2007 | 08:05 PM
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
It would be very durable also. It adds too much weight though.
Old Apr 20, 2007 | 08:32 PM
JACKAL0PE's Avatar
JACKAL0PE
Lepus-temperamentalus
Why not something like Cascade Vblok Quiet-Kote or Dynamat Dynashield?
To Undercoating/Bedliner: Pros and Cons
