400 block in a C3... need advice!!!!
Old Apr 8, 2007 | 11:40 PM
JCBand's Avatar
JCBand
2nd Gear
Default 400 block in a C3... need advice!!!!
Hey out there, i just picked up a 400 block and am going through all the options... i have a few g's to do it, the motor is out and now i'm weighing my options.
Should i go to a 406? that adds up to $$$ i already have had the block honed with new bearings and rings... is it worth it to scrap it and get new everything including pistons etc...to bore it out?
What Heads should i use?
Any other advice would be great. If there is someone out there with this combo... i'd appreciate the heads up.
Or-- Maybe just get a crate motor? Which one?
The car is a 74 Black on Black, has Guldbrand suspension, custom no seam mako style body and a bitchin custom all leather new chrome interior.
whew!
Old Apr 9, 2007 | 03:11 AM
74and76cpl's Avatar
74and76cpl
hey cool, me and my wife are goint to be putting a 406 in our 76. from what i hear the 400sb can be a real good and strong engine.as far as boring your to a 406 i wouldnt wast the bore if you dont need to save for another rebuild later on. ours was built to make arouund 480hp roler rockers the heads are stock but have been ported and polished bigger valves we still have to get the build sheets so i cant give cam specs but it does have a pretty rad cam im alittle concernd about making vacum for the breaks and lights but we can deal with that when it comes. but good luck i have always liked small blocks for the street.
Old Apr 9, 2007 | 08:28 AM
Artsvette73's Avatar
Artsvette73
Just a heads up. Check the front of the block to see if it is drilled and tapped for the power steering pump bracket.
Old Apr 9, 2007 | 12:57 PM
Hotrod406's Avatar
Hotrod406
Don't bore it unless there are scratches. You can go .030, usually .040, but that's it. My 400 block is .030 already and should be bored again. It has deep scratches that won't clean up at 10 more thou, so I have to leave it.
Sounds like you should talk to a local shop and have them suggest some options.
Old Apr 9, 2007 | 03:35 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Not true. A good 400 block can go to .060 easily. I have a bare block in my basement at .060 that was original built as a race engine, before the cylinder heads cracked (idiot probably didn't drill the steam holes).
Old Apr 9, 2007 | 06:23 PM
Aflac's Avatar
Aflac
Cruise-In 5, 6 & 10 Veteran
St. Jude Donor '09
I agree they can but remember, the thiner the walls, the more heat you generate. These cars don't fare too well on the cooling aspect as it is already...
Old Apr 9, 2007 | 06:35 PM
Corvette Engineering's Avatar
0Corvette Engineering
Former Vendor
My 434 built in 1998 says differently.....runs about 210 even on 95+ humid days with the smallblock brass radiator.
Just remember to calculate your compression, the extra 50 cubeswill give you a lot more compression!
Oh and get a big cam, again, another 50 cubes!
Keith
Owner of Corvette Engineering AND a Corvette
Old Apr 9, 2007 | 07:14 PM
Hotrod406's Avatar
Hotrod406
I doubt it, but I'll have my block sonic'd too see if that's possible the next time it's apart.
Old Apr 10, 2007 | 01:57 PM
jackson's Avatar
jackson
Suggest:
  • Have a pro check the 400 block very closely.
  • If the block checks good & no cracks around bolt/water holes ... build the 400.
  • Bore to +30 as there are VERY FEW piston choices in +20 for 400.
  • Use longer than short OE 400 rods ... at least 5.7" ... 6" are great & inexpensive.
  • Pick your pistons wisely ... compression/dome volume AND Height.
  • Choose a piston and then ZERO-deck the 400 block to that piston ... that's because there are VERY FEW head gasket choices for 400 ... aside from some copper sheet, there are NO thin gaskets for 400 (350 gaskets will NOT last) ... so zero-deck and use a typical 400 gasket to set a good quench height. I suggest this deck approach for 400 but not 350.
To 400 block in a C3... need advice!!!!
