C3 Body Removal
Hi, we are trying to pull the body off the frame on a '71 coupe. We have found the 1st, 3rd and last bolts, and believe we know where the 2nd one is (inside the front door jam?). There are a couple of problems that perhaps someone here can help us with.
As always we soaked everything down with PB Blaster and after tapping on the bolts, let it sit for a day. The first bolts came right out. The 4th bolts both rounded of the head because they were rusted so tight they would not move (remember I have kids doing this and they do not know the difference between a head that is stripping and a tight bolt that is slowly turning).
So here are my questions. First, I will no doubt have to burn the heads off the back #4 bolts, but then what? Are those bolts/nuts captive to the body somehow? If so how do we get them out once the body is off?
Second , what is the best way to get to the #2 bolts that for all appearances seem to be inside the front door jam?
The #4 bolts I found easiest to remove the cage from inside the Vette all the way in the back corners. I used a cut-off wheel and removed the cage and nut, the bolt then fell out from the bottom.
Good Luck!
#4 ... I used a 4" grinder to take the head off.
The nut for #4 is captive (cage nut) ... accessible from inside the body.
However, to replace the cage nut, you must remove the #4 body
mount reinforcement.
Some pics here:
http://forums.corvetteforum.com/show....php?t=1666561
Once the body was lifted I was able to remove the remaining studs from the nut cages using a littel heat and some vise grips.
Good Luck
except that one forward of the rear wheel...ain't that a bugaboo!!
