What is the difference!?
Old Apr 12, 2007 | 11:32 AM
randommj's Avatar
randommj
Default What is the difference!?
what is the diff. between the L-48 and the L-88 mechanicaly? i know the obvious HP difference, would it be possible to "transform" my L-48 into an L-88? im thinking begger CAM push rods, springs, rocker arms etc etc, but wut else?
Miles
Old Apr 12, 2007 | 11:33 AM
sperkins's Avatar
sperkins
You mean L82?
L48 - 2 bolt main block
Years: 1970-1980
The L48 was the standard engine on the 1971 Chevrolet Corvette. It produced 270 hp (201 kW) and 360 ft·lbf (477 N·m) with an 8.5:1 compression ratio.
The 1976-1979 L48 was the standard Corvette engine and produced 180 hp (134 kW) and 270 ft·lbf (366 N·m). The 1980 L48 stood at 190 hp (142 kW) and 280 ft·lbf (380 N·m) from 8.2:1 compression.
In 1973 the "L-48" had cold air induction (throttle activated) and developed 190 hp (net). Beginning in 1974 the hp was reduced for several years until it reached a low of 165 (net) in 1975 or '76, before rising again.
L82 - 4 bolt main block, forged crank
Years: 1973-1980
The 1973-1974 L82 was a "performance" version of the 350 producing 250 hp (186 kW) and 285 ft·lbf (386 N·m) from 9:1 compression. It was down to 205 hp (153 kW) and 255 ft·lbf (346 N·m) for 1975. It was the optional engine again in 1976-1977, producing 5 hp (4 kW) more. The 1978 L82 recovered somewhat, producing 220 hp (164 kW) and 260 ft·lbf (353 N·m), and 5 hp (4 kW) and 10 ft·lbf (14 N·m) more for 1979. 1980 saw another 10 hp (7.5 kW) and 15 ft·lbf (20 N·m).
Old Apr 12, 2007 | 11:38 AM
randommj's Avatar
randommj
Originally Posted by sperkins
You mean L82?
hhh yea i do, im sorry :o
Miles
Old Apr 12, 2007 | 01:58 PM
randommj's Avatar
randommj
thx fot the info!
what is different between them, what does the L82 hav that the L48 does not?
Miles
Old Apr 12, 2007 | 02:56 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
4bolt main block, Forged crank, higher compression due to different pistons, longer duration camshaft.... I think that's about it....
Old Apr 12, 2007 | 09:21 PM
Kneel 8250's Avatar
Kneel 8250
St. Jude Donor '11-'12
Miles,
You could rebuild your engine with higher compression pistons to give around 10:1 compression ratio, an RV cam with a lift of around .490 and stronger double valve springs. Open the ports of the heads up a little and then polish them and you will have more horsepower from the engine than the L82. The advantage of this type of build is you maintain driveability and can run premium pump gas and retain a stock appearing motor. When you have the funds available replace the stock headers and the inlet manifold and go bigger on the carburettor.
After that it is how deep are your pockets and how fast do you want to go.
Have a great day and enjoy that vette.
Old Apr 12, 2007 | 10:31 PM
randommj's Avatar
randommj
thanks guys, question awnsered! like my dad says every time he see's me on the forum: "that thing is so great for you, you hav so much information within such an easy grasp"
i love this place!
Miles
Old Apr 13, 2007 | 12:18 AM
Tom73's Avatar
Tom73
This may help some. It is for the '73 but the '74 is basicly the same setup.
Old Apr 13, 2007 | 03:02 PM
NHRalph's Avatar
NHRalph
Ya, just a better cam, 4 bolt main and different pistons for a higher Comp. ratio, otherwise both blocks
from, I believe 1969 were 3970010's. Most years the heads were the same also except for bigger valves in L-82.
Old Apr 13, 2007 | 03:23 PM
NHRalph's Avatar
NHRalph
TOM73, that is a great example. I put my 2 cents in before seeing your thread. I think from 74 on the heads were the same except for valves, 333882 until 78. I did learn a lot from your example, especially the cam grinds. Thanks.
Old Apr 13, 2007 | 05:29 PM
sethjohnson71's Avatar
sethjohnson71
Funny thing, when I was rebuilding my 74 L-48 it had 4 bolt mains! I thought that was weird.
Old Apr 14, 2007 | 12:51 AM
copter's Avatar
copter
I know what you mean but there are a bunch of 4 bolt main L48's out there from the factory.It's when you ordered an L82 and find out it has 2 bolt mains, and I'm sure there are some of those lurking around
Old Apr 14, 2007 | 06:19 AM
Aflac's Avatar
Aflac
Cruise-In 5, 6 & 10 Veteran
St. Jude Donor '09
if i remember right, also add to the list dual valve springs on the 82's but don't quote me on that...
Old Apr 14, 2007 | 11:47 AM
Bee Jay's Avatar
Bee Jay
The L-82 springs were a little stiffer, but still almost junk. When I ordered my 79 the dealer could not understand why I would pay so much for only 30 additional horsepower. I said are you kidding? 2.02 heads, forged pistons,rods, and crank, four bolt block, more compression, and a big cam. I'm paying for potential.
First thing I did was to remove the catalytic converter and slap an edelbrock performer manifold on. What a difference getting some of that potential out.
Bee Jay
Old Apr 14, 2007 | 07:26 PM
aussiejohn's Avatar
aussiejohn
Default Aluminum rocker covers
Tom,
Great info, it taught me some things I didn't know. However, I thought in '74 (at least) that the inlet manifold and rocker covers were aluminum on the L82, can you confirm?
Not too many people with this knowledge down in the Antipodes.
Regards from Down Under
aussiejohn
Old Apr 15, 2007 | 01:18 PM
NHRalph's Avatar
NHRalph
AussieJphn, I just looked in my books and in 1974 the intakes for the L-48 and L-82 had the same casting number..340261. Hope that helps.
NHRalph's Avatar
NHRalph
Aussiejohn, sorry for the misspelling of your name in last thread!
To What is the difference!?
Old Apr 15, 2007 | 10:07 PM
Tom73's Avatar
Tom73
Originally Posted by aussiejohn
Tom,
Early L82 had iron intakes. The later years, last 2 maybe 3 years [maybe 77 and on or 78 and on], of the L82 had an alumn casting. Believe, but cannot confirm, that the alumn casting was identical to to iron so the only difference and performance advantage would be a weight reduction.
tom...
Old Apr 16, 2007 | 10:26 AM
NHRalph's Avatar
NHRalph
Tom, maybe 1978, my books do not go past 1977, The 1977 versions were the same, casting number34649. But your right, only difference would be weight. You'd gain more horsepower by placing an STP decal in your rear window!
Old Apr 16, 2007 | 02:16 PM
stingr69's Avatar
stingr69
Nearly everthing on an L-82 engine is different in some way. One of the only things that never changed during this time was the valve springs. There is only (1) valvespring for all the factory SBC engines. , L-48's, L82's, DZ 302 Z/28's, station wagons, you name it. They all had the same valvesprings.
-Mark.
