...WHAT RETURNS THE PEDAL TO SWITCH????...IS THERE A SPRING OR IS IT BY PRESSURE??? If spring where does it go and where to buy?
Buy the AIM; it has an illustration of exactly what you want and how it installs. There is a brake pedal return spring which pulls the assembly back up and to the stop light switch after the brakes have been applied. Not sure whether the springs are available from the aftermarket providers.
In a pinch, you can buy a generic coil spring from most hardware stores. Connect one end to the pedal arm and the free end under the dash. Pedal will return to normal position with the "fix" applied.
