Replacement A/C Condensor for R134A?
Old Apr 16, 2007 | 07:05 PM
79vetter's Avatar
79vetter
Default Replacement A/C Condensor for R134A?
What do you guys recommend replacing the stock Condensor with when going to 134?
If you have a link to something that would be great
Old Apr 16, 2007 | 08:46 PM
wnmech's Avatar
wnmech
I have converted several cars from R-12 to R-134 and Have never changed condensors. I have always replaced the receiver dryers and orifice tubes and flushed out the condensor and evaporators out before recharging. I plan on either using R-134 or freeze 12 when I get my vette that far. R-134 will cool alright unless you are at Idle and you dont get enough air moving thru the condensor to cool things down. If you switch to an electric fan you will get better R-134 cooling. It operates at much higher pressures over R-12 and generates more heat especially at slow speeds.
Old Apr 16, 2007 | 10:29 PM
SIXFOOTER's Avatar
SIXFOOTER
This is what your looking for. The stock unit will work, but all the ne systems use the paralell flow condensors because they are more efficient
http://www.ackits.com/merchant.mvc?S..._Code=Parallel
Old Apr 17, 2007 | 08:42 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by wnmech
...I have converted several cars from R-12 to R-134 and Have never changed condensors...R-134 will cool alright unless you are at Idle and you dont get enough air moving thru the condensor to cool things down. If you switch to an electric fan you will get better R-134 cooling....
To Replacement A/C Condensor for R134A?
