Interior Dye Application Question
Old Apr 16, 2007 | 10:14 PM
pra4sun's Avatar
pra4sun
Default Interior Dye Application Question
I bought some spray can dye from Corvette America to spray some new hard plastic parts I just bought, plus spray some older soft and hard interior parts.
Here is my game plan:
New Parts: Clean with rubbing alcohol, apply paint in thin coats every 10 - 15 minutes.
Old Parts: Clean/Degrease, wipe down with rubbing alcohol, apply paint in thin coats every 10 - 15 minutes.
Here is the question: I also bought a can of Interior Dye Primer, and I have not seen any mention of anyone using this while searching the forum. Is it even necessary? I thought it might be because I am going from the black that the new parts are molded in to Light Saddle. Am I correct, or should I just return it?
By the way: Corvette America dye is a re-wrapped can of Omni Pak MasterBlend, made by Krylon. This must mean that Corvette America custom blends and fills their own cans.
Old Apr 16, 2007 | 10:34 PM
MikeMc71's Avatar
MikeMc71
On the hard plastic, I used a product called "Bulldog" first. It really helps the dye to adhere to the plastic. (Heard this from an "old" interior guy).
Old Apr 16, 2007 | 10:58 PM
DZRick's Avatar
DZRick
I think the primer would be a good idea as you are going from black to a much lighter color, I've never dyed parts but it seems like cheap insurance IMHO.
Mike,
Who makes this Bulldog product?
Rick
Old Apr 16, 2007 | 11:04 PM
David Ey's Avatar
David Ey
Absolutely use this first....after cleaning. You won't need primer but prime if you wish. I cleaned with Comet and a fingernail brush.
Old Apr 16, 2007 | 11:58 PM
MikeMc71's Avatar
MikeMc71
The Bulldog is made by Klean-strip.
Old Apr 17, 2007 | 12:03 AM
mooneyd's Avatar
mooneyd
I did mine exactly the way you mentioned, without primer, and it came out perfect. Went from dark blue to charcoal, and also some new pieces. Use very thin coats and as many as needed to get the results you want. An easy job. Good luck. Check out My Corvette Photos to see the interior.
Dave
Old Apr 17, 2007 | 08:09 AM
bluesilver82's Avatar
bluesilver82
I have only dyed one part in my car and that is the power seat switch bezel. Dark Blue. It was a new bezel. I cleaned it first then put 4 coats on it. A year later the dye is fading on the top edge. I assume it is fading from the bezel being rubbed when getting in and out of the car.
Old Apr 17, 2007 | 12:11 PM
MN81C3's Avatar
MN81C3
I redyed (silver) most of the window and t-top trim this winter. I follow the same procedure you mentioned - except i cleaned the parts with Laquer thinner first to get off all grease and then cleaned with rubbing alcohol. most of my parts were being dyed the same color but i did dye a few new black parts. I also bought the primer and used it on one black but not the other. I saw no differance. I did use the clear coat protectant on the power seat switch bezel which was orginally black. it darkened it a bit but i hope it will last longer.
I also used the dye on the steering column and related parts - worked great!
Old Apr 17, 2007 | 07:25 PM
bobbywyant's Avatar
bobbywyant
I used the corvette Amercia spray cans ,ordered primer and used one can,then did the rest without. Came out Great went from doe skin to firethorn. If i had it to do again would buy it by the quart, took about eight cans! Just clean the parts good lacyuer thinner works great.
Old Apr 17, 2007 | 07:33 PM
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
I just cleaned mine with acetone and sprayed them with one coat. I used the crap from discount auto parts. Duplicolor I think. I was only putting a coat of the same color(black) to cover some crap and make it look better. Did it about 2 minutes ago lol. ran out of paint though
Old Apr 17, 2007 | 08:11 PM
pra4sun's Avatar
pra4sun
Thanks for all the useful info.!
I think I'll use the primer on the black parts, and knowing me, I'll want to dye the whole interior soon enough. In that case, I'll just order a quart of dye and forget about the primer.
Old Apr 18, 2007 | 07:46 PM
Bow-Tie Guy's Avatar
Bow-Tie Guy
I also picked up some dye (Silver Pace) from Corvette America along with one can of their primer. The instructions for the primer says to spray it on the part first, then wait a few minutes and spray the color on top (while the primer is still wet). Then continue to spray light coats of the colored dye every 10 - 15 minutes after that.
I think spraying the color onto the damp primer is so that the first coat of dye "bonds" with the primer on the part. I'm sure that's what the "bulldog" does as well - but without the slightly higher price of the CA primer...
In any case, it worked well for me. Good luck!
Old Jun 26, 2007 | 10:01 PM
rfhall50's Avatar
rfhall50
Default Dye job looks great, but ..........
Just finished dyeing the interior parts. The leather and soft rubber pieces are really great. I am using Corvette America dye (1980 Red). I am also dyeing the hard plastic pieces such as around windshield, hinge covers on seats, etc. These also turned out great.
Each part was scrubbed with Comet, rinsed throughly, allowed to dry for two days. Before starting to spray, I washed my hands thoroughly, sprayed each with SEM Sand Free, and sprayed each while the SF was still wet. I had each hanging by some stiff wire through an available screw hole.
THE PROBLEM: When I removed the wire from some of the hard plastic pieces (specifically the seat hinge covers), some of the color scratched off. This may not be a problem with the pieces around the windshield that are rarely touched, but the hinge covers (and the seat frames that I haven't done yet) will get a lot of wear.
WHAT CAN I DO TO BETTER PREP THE HARD PLASTIC PIECES ???
AM I USING THE CORRECT DYE/PAINT FOR HARD PLASTIC ???
Thank you. I appreciate your input before I mess up the seat frames.
Bob
Old Jun 27, 2007 | 01:37 AM
bluegtp's Avatar
bluegtp
i've just finished dyeing all of my interior pieces from tan/red to black......here's a picture of my new dash from ecklers....the glove box is original and I used the dupli color interior paint/dye.....i think it came out pretty darn well......matches great too! i put it in the sun so ya'll can see the color better..
as for the hard pieces use a primer...and a decent amount of coats....
Old Jun 27, 2007 | 03:35 AM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Old Jun 27, 2007 | 05:03 AM
hunt4cleanair's Avatar
hunt4cleanair
I played around with some silver color for a Pace Car and it came out somewhat flat. The recommendation is to use some of the satin clear finish lacquer...anyone play with it?
Old Jul 23, 2007 | 05:03 PM
SeattleC5's Avatar
SeattleC5
I was about to say the same thing. I have always put 2 clear coats on top of the new dye color coat. That seems to make everything more durable. I have used polyurethane rather than spray lacquer.
Old Jul 23, 2007 | 06:13 PM
toddalin's Avatar
toddalin
You're going from black to light saddle???
Recognize that the threads in the various pieces (e.g., the center console) are a different color than the actual vinyl piece and you will never get the thread color exactly right (regardless of what color you go from and to).
Also, the dye will "glop" these threads together and they will never be the same.
I had a green/green '70 so any replacement pieces always had to be dyed and this was my experience.
To Interior Dye Application Question
