lifting body help
Old Apr 17, 2007 | 02:24 PM
jimmie guidry 1967's Avatar
jimmie guidry 1967
Default lifting body help
I'm about to remove the body from frame on my 69 vert.Should i remove the windshield before,and do i need to somehow place somekind of brace between the doors to strengthen the body? If it had a roof i wouldn' be as worried about the lifting straps squeezing the doors and damaging the body.Thanks for any info.
Old Apr 17, 2007 | 02:35 PM
68 NJConv 454's Avatar
68 NJConv 454
I lifted my vert with the roof still on it which provided some side to side strength.
I think your doors will be fine as long as you attach the straps at the very front of the doors and rear of the doors to spread the load.
Do not take the doors off or windshield out.
A few have put the straps on with the doors open, then closed them to act like a supporting member, this way the straps are on the inside of the door. I don't know if this method is a good idea.
Make sure you put a strap to the front of the radiator frame to support the nose of the body and someone will have to hold the rear of the body too. Both rear deck and nose will need to be supported or your worste nightmare could happen...in the least some cracks in the paint from stress.
I rested my body on jack stands in the rocker channel, supported the rear with a bunch of old tires and the front using another jackstand.
Good luck.
Here's a few pics of my lift process.
Body on jackstands...
Old Apr 17, 2007 | 02:38 PM
rick1500's Avatar
rick1500
I attached the straps to the seat belt anchors that bolt to the rocker channels inside the car. I didn't have a proper set of lifting straps though, but that might work for you if you're concerned about pressure on the doors.
Old Apr 17, 2007 | 05:56 PM
jimmie guidry 1967
Thanks for the advice.
Old Apr 17, 2007 | 06:12 PM
redwingvette's Avatar
redwingvette
I used a 2x4 cut a little longer then the distance across the doors so the straps did not pull in on the door skins.
Old Apr 17, 2007 | 06:13 PM
1ARACE's Avatar
1ARACE
Good luck.
I ran straps at front of door, opened doors...ran back of doors, and a nose strap. Is good idea to have someone holding front, even with the strap on it, to eleviate stress, and another at the back to counterbalance/manuever the body. I sat it down on a lot of rubber tires.
Can kinda see in this pic.
Old Apr 17, 2007 | 06:26 PM
NHvette's Avatar
NHvette
IMO, the best thing to do before lifting the body is to remove all that you can (weight).
Doors, headlight assemblies, bumpers and supports, seats, steering column, etc etc.
Second, make sure the birdcage is strong enough to lift with.
Reach under the door area ... and grab between the frame
and rocker channel. Pull up and out ... should be VERY strong.
Any chunks of rust/flexing and it will not be safe to lift conventionally.
Old Apr 17, 2007 | 07:38 PM
Timmijoe's Avatar
Timmijoe
so what would be the proper way to support the body when he needs to remove the rocker channels? are the floorboards strong enough?
Old Apr 17, 2007 | 08:49 PM
redwingvette
Yes, I built bucks that fit under the floor pans and blocked up the front and rear area with saw horses. Leaving the doors on gave some added strength to the bird cage once the rocker channels were removed and gave me something to reference the positions of the new ones when I was welding them in place.
Old Apr 17, 2007 | 10:56 PM
RobRace10's Avatar
RobRace10
I just lifted my 69 vert body last weekend. I did it wthout the front clip, but still tied the door stricker to the door hinge with an adjustable rod to make sure I did not tweak the body.
Old Apr 18, 2007 | 12:51 AM
gkz's Avatar
gkz
I visited a local place that restores vettes and asked them the same question. Their answer was the front and back tend to sag, causing the birdcage to split. Based on Noland Ryan's video, I decided to support the missing doors with this setup:
This is a 1/2"x 6" coarse eyebolt screwed into the shoulder harness mount. This was good for me because my #4 mount cushions were decomposed, causing the aft door gap to taper from 1/8" @ bottom to over 1/4" @ top. As the eyebolts screw in, they eventually seat against the top of the frame rail. As you continue to tighten the eyebolt, it will force the tail up, correcting the gap caused by sagging.
The front is a turnbuckle bolted to the door hinge (with a door bolt) and attached to a chain. Thread the chain through the eyebolt and fasten it together with a bolt and Nyloc nut. Tighten the turnbuckle to remove slack until just barely lifting the eyebolt off the frame; then, loosen to where the eyebolt sets against the frame.
I don't know what type chain this is, but it was strong enough to remove a 300cu in inline six from a '65 F100.
Hope this helps...
To lifting body help
