T-Top is Bent
Old Apr 18, 2007 | 10:18 AM
79vetter's Avatar
79vetter
Default T-Top is Bent
My passenger side T-Top is a little bent at the front towards the windshield whereby someone, I think, tried to pry it off. The effect is that I can see into my new interior from outside the car
The question is: Is it possible to bend the fiberglass back to its original position or is a new T-top the only way to go?
Old Apr 18, 2007 | 10:29 AM
SIXFOOTER's Avatar
SIXFOOTER
Fiberglass doesn't bend that much out of place and stay thay way, it breaks. Take the top apart and see if its cracked or what, you might be able to fix it. It could be warped which means its toast. Also look carefully at the top mounts, make sure the issue is not dammage to them.
Old Apr 18, 2007 | 11:54 AM
randommj's Avatar
randommj
under the front "tooth" that holds it in place see if there is a schim inder it and the body of the T-top, if there is take it out and see if that pulls it down anymore, the roof lining pops right off
Miles
Old Apr 18, 2007 | 01:33 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Got a friend with a coupe? Try his/her top on your car. If the problem exists with a different top, the windshield frame is the culprit.
Old Apr 18, 2007 | 01:43 PM
Ak. Mal's Avatar
Ak. Mal
From: Kansas City, MO ...I'd like to go fishing and catch a fishstick. That'd be convenient. - Mitch Hedberg
My passenger top suffers from a bowed high point in the front center too. I don't have the headliners in and never noticed I could see between the top and the windshield until after I changed the weatherstripping.
Old Apr 18, 2007 | 01:50 PM
gq82's Avatar
gq82
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
I've seen many, many windshield frames bulge from rust building underneath especially in the corners.
Old Apr 18, 2007 | 04:03 PM
Lon Wayne's Avatar
Lon Wayne
Default Vader Vette
My 77 and My 75 Sold the 77 but they both had T-Tops that did not look the same when on One fit fine the other was 1/8 inch higher .I dont see how to adjust that unless you just put weight on the front,and bend it back down, the top fit fine it just looks higher on one side.
Old Apr 18, 2007 | 08:08 PM
79vetter's Avatar
79vetter
How do you keep the water out? Here are a couple of pics.
Old Apr 19, 2007 | 12:28 AM
Ak. Mal's Avatar
Ak. Mal
I try not to drive in the rain. My door glass is also really out of alignment. I tried for two weeks last year to fix that before I gave up.
My passenger top does look similar to yours. I tend to only use the tops when parking to lock the car up, so replacing it isn't really a high priority.
Old Apr 19, 2007 | 01:32 AM
TimAT's Avatar
TimAT
I wonder if you could put a heating pad and sandbags on there to "bend" it back down? Provided the windshield frame is not the real problem.
To T-Top is Bent
