Paint For Engine Brackets
Old Apr 22, 2007 | 08:53 PM
724544SPD's Avatar
724544SPD
Default Paint For Engine Brackets
I bead blasted all of my engine brackets and sprayed them with Rustoleum. I've had good success with Rustoleum on previous engine builds but am concerned with how it will do on the A/C mounting bracket that mounts on the passenger side exhaust manifold.
Will it bake off? Should I spray it with high temp paint?
Since the bracket will be a PITA to re-do once installed, I want to make sure I don't have to do it twice.
Old Apr 22, 2007 | 10:06 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
i use rustoleum alot and have been happy with it....for that bracket why not get hedder primer and hedder paint and then cure it in your home oven? when the Mrs is out?
Old Apr 22, 2007 | 10:46 PM
willem wallace's Avatar
willem wallace
Default Rustoleum 1200
Rustoleum makes a Hi Temp in both blacl and copper, good to 1200 degrees.
To Paint For Engine Brackets
