Metalworking Tools
Old Apr 23, 2007 | 11:58 PM
stinger12's Avatar
stinger12
Default Metalworking Tools
I'll begin repairing my birdcage and floorpans in the next week or so. I already have a welder. I'll be needing to make patches for both the floor and birdcage - specifically where the seat belt retractor bolts to the floor and the lower windshield corner, where the front clip attaches to. Which tools do I need to make patch panels? Ball peen hammer? Anvil? I have a nice die grinder and electric makita grinder as well. I'm talking sheet metal patches, not frame rail patches. Please, I am in need of opinions of the tools which I will need...there are so many choices.
Old Apr 24, 2007 | 01:37 AM
TimAT's Avatar
TimAT
A good vise, assorted sizes of heavy pipe for radius bends, and a small sheet metal brake. And a good set of aviation tinsnips, left, straight and right. Should get you started..
Old Apr 24, 2007 | 08:17 AM
Tommy Samuels's Avatar
Tommy Samuels
I'll add to this list a heavy duty bag filled with wet sand and a couple of body hammers. You can lay your part on the bag for wupport and "fine tune" it with the hammers.
Metalwork is more art and practice than science.
Old Apr 24, 2007 | 11:29 AM
Black 82's Avatar
Black 82
In addition to those mentioned above;
- Hand Brake
- Punch and Flange tool unless you're doing all butt weld seams
- Lots of wide jaw vise grips
- Lots of those magnetic triangle things
- Copper Spoons for backing up butt welds
- Harbor Freight shear http://www.harborfreight.com/cpi/cta...emnumber=92115 This is the best thing for cutting blanks out of sheet stock.
- Right Angle Grinder and Straight Cutoff Wheel
- Eastwood Spotweld cutter
Old Apr 24, 2007 | 12:31 PM
NHvette's Avatar
NHvette
I did just fine with my 4" grinder/cutoff and my big Chinese anvil.
Cheap money.
Get some flap disks for the grinder - for final cleanup welded seams.
Yeah - the magnets are key - need a few of those at a minimum.
Old Apr 24, 2007 | 01:02 PM
SIXFOOTER's Avatar
SIXFOOTER
I used a 4" cutoff wheel, jig saw with metal blades, 3lb short handle sledge, a big vice with anvil and a piece of carpet to shape the inside bends. I used the vice, hammer and large flat chisel to form the bead for the glass on the lower WS frame corner.
I didn't have ANY sheetmetal experience, but I cut a pattern out of cardboard and went from there.
Old Apr 24, 2007 | 01:11 PM
79L82owner's Avatar
79L82owner
Default hmmm???
If you need all those tools listed above by these guys, it might be cheaper and easier to just buy a new Vette.
Old Apr 24, 2007 | 06:45 PM
stinger12's Avatar
stinger12
bump
Old Apr 25, 2007 | 07:29 PM
stinger12's Avatar
stinger12
bump
Old Apr 26, 2007 | 12:51 AM
gte718p's Avatar
gte718p
I've built entire cars with a die grinder, hammer, vice grips, and a vice. Cut, bend and hold are the absolute essentials. Everything else makes life easier and nicer but is not necissary. If you have the money, a plasma cutter is the most wonderful piece of equipment ever made. I'll never go back. It makes clean percise cuts in no time. Surgical removal of old metal is a easy.
Old Apr 26, 2007 | 11:24 AM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
really you need just cutting tools and a variety of hammers......use carboard and fabricate your pieces in metal after making a mock up of it in card board.....and remember you can weld things together as well as beat them into submission
Old Apr 26, 2007 | 06:43 PM
stinger12's Avatar
stinger12
bump
To Metalworking Tools
