Headlight door adjustment
Old Apr 25, 2007 | 04:59 PM
JimT's Avatar
JimT
Default Headlight door adjustment
My driver side headlight door will not open all the way "up". I've loosened the "up" stop on the right side of the door (doesn't help), I can adjust the "down" position with the appropriate screw, but I cannot seem to determine why the door will not open all the way up. I have removed the actuator push rod but still can't force the door all the way up. I cannot remove the headlight bezel without pushing up on the door. Has anyone had this problem?
JimT
Old Apr 25, 2007 | 06:55 PM
Corvette ED's Avatar
Corvette ED
From: Pottsville, PA. USA Home Of America's Oldest Brewery Yuengling
With the headlight bezel off on the outer side there is a black bracket that is held on by two bolts. Remove the bolts and take it out there is a rubber stop that adjusts on the backside of the bracket. That could be your problem.
