How to control cabin heat?
Old Apr 26, 2007 | 12:33 PM
dobroman2001's Avatar
dobroman2001
Default How to control cabin heat?
Finally got my '76 on the road!!
I noticed that heat was coming out of the vents. I don't have the heater core hoses connected and I thought that I could control the heat somewhat by changing the Climate Control to MAX/AC which would close the outside vent (would not let fresh air into the car). This didn't seen to chage the amount of heat coming from the vents. Any ideas?
I don't have carpet... or basically anything in the interior with the exception of the dash and the drivers seat so I was expecting it to be a little warm but....
Thanks,
Old Apr 26, 2007 | 12:53 PM
Young69Owner's Avatar
Young69Owner
Put it to "OFF" and if they doesn't close check your vacuum connection by the shifter. They have been known to fall off. Do all your other vacuum-operated gadgets work?
Young69Owner
...they don't...
Old Apr 26, 2007 | 01:10 PM
mxscooter's Avatar
mxscooter
I was having huge heat problems too, this forum was a big help in doing a couple things - first, I put in a couple shut-off valves in the heater lines (you said your core is diconnected anyway, so nevermind that one), then heat still radiated into the cabin, so I disconnected the power to the blower motor, and heat still came in from the vents, so I got frustrated and ghetto-taped the vent openings shut.
If you have carpet and such out of it, now would be the best time to install some sort of heat-barrier to the firewall, trans tunnel, and floors. I wish I had done it when I was putting mine together, and now look at
me - ghetto-taping stuff
Old Apr 26, 2007 | 01:15 PM
SIXFOOTER's Avatar
SIXFOOTER
Check out the vac switch in the console as mentioned above. One of the devices that operates is the outside air door on the pass side of the wiper tray. Behind the screen is a vac operated flapper, vac applied it is supposed to close off. The vac comes from the vac switch, thru the gromet on the firewall, back thru a hole into the tray and then to the door operator. Would be a good time as mentioned above to fix all them lil gizmos and close up the leaks in the ducts. Do yo have AC? Does it work?
Old Apr 26, 2007 | 01:27 PM
mxscooter's Avatar
mxscooter
Uh oh, what does AC not being hooked up have to do with it?
Also, if his heater core was bypassed/not connected, and that little flapper dealie was open, would the result be engine compartment heat rolling into the cabin thru the open port?
PS - I only used tape because I was in a hurry...
Old Apr 26, 2007 | 01:32 PM
Young69Owner
If you can hear vacuum leaks right after you shut your car off (hissing air), then try to pinpoint those hoses and fix them. If it's not a leak, then make sure you have a vacuum line connected to your carburetor and follow it to see if looks good. You should have a vacuum reservoir, lines going to your lights, and lines going into your firewall. Maybe we can end up fixing some of this stuff while we're working on your vents.
Old Apr 26, 2007 | 02:06 PM
SIXFOOTER's Avatar
SIXFOOTER
AC may have nothing to do with it depending on how it was disconnected and Yes, if that flapper is open you will definately get engine heat in the cabin
Old Apr 26, 2007 | 03:25 PM
1Z87L8's Avatar
1Z87L8
on my 78 i didnt have to put extra valves
after reading on the list here i checked and found
that my shut off valve was not holding vacuum.
bought a replacement and that took care of about
70% of the problem.
the second fix i did was the actualy vacuum switch
under the dash located in the heater box, i got to mine
by removing the glove box,
i found that it had slipped over the years and the cable
when put to the cold position was not fully turing to cold
i re-adjusted it so once in cold position it is fully off.
had the car out monday when it was 83 here and it was a pleasure
to drive.
Old Apr 26, 2007 | 03:43 PM
dobroman2001
Yeah, I do have A/C and it is not working. I'm pretty sure that all the vacuum lines are OK... and I just fixed the valves at the kick panel and outside so I know they are working. The engine is running smooth so I assumed that all the lines under the hood were OK. I can double check that...
Old Apr 26, 2007 | 09:07 PM
SIXFOOTER's Avatar
SIXFOOTER
Well, sounds like you need to get in there and make sure you have vac at all the doors (4 on my car) when your supposed to. There are 2 that close off the outside air, the one for outside air and the one in the pass side kick panel
Old Apr 27, 2007 | 11:04 AM
gliot1's Avatar
gliot1
St. Jude Donor '12-'13
When I replace my carpet I added Reflectix underneath......big help. Also many of the guys in our club put in a shutoff valve in the heater core hose, another big help. Corvettes all run hot, so you kind of get used to it a bit! You ought to ride in a mid-year!
Old Apr 27, 2007 | 04:02 PM
Paul L's Avatar
Paul L
Gliot,
I do. A 1967 coupe with no A/C. Can get very hot. These louvered lower splash shields pull engine heat away from the firewall and down under the car.
To How to control cabin heat?
