flywheel question
Old Apr 28, 2007 | 10:02 PM
toolman0114's Avatar
toolman0114
Default flywheel question
I have a 1974 coupe with a 350, 4- speed, I want to replace the starter but don't know if the flywheel has 153 or 168 teeth, it has an 11 inch clutch disk, does anyone know? I don't feel like crawling underneath and trying to count them, thanx.....
Old Apr 28, 2007 | 10:20 PM
Gordonm's Avatar
Gordonm
The 11 inch clutches used a 168 tooth ring gear. The starter bolts should be offset on the 168 and straight across on the 153.
63mako's Avatar
63mako
St. Jude Donor '08-'09
11" disc = 168 tooth................... EDIT: Gordon is pretty quick on the keyboard.
Old Apr 28, 2007 | 10:24 PM
toolman0114
Thanx for the help......
Old Apr 29, 2007 | 08:15 AM
Gordonm's Avatar
Gordonm
If you only knew how slow I was on the keyboard. I have improved due to the forum. Just practice I guess.
To flywheel question
