Need help with Ignition Shield installation
Old May 1, 2007 | 08:15 PM
Plum Different 73's Avatar
Plum Different 73
Default Need help with Ignition Shield installation
Could anybody give me some feedback on installing an Ignition Shielding set up on a 73 - 350CI? Tech Articles, illustrations, pictures, or whatever.
I've got: (All the items that a Corvette America rep said I would need)
1. Top Chrome Shield
2. L&R Top Shield brackets
3. L&R Chrome Vertical Shields
4. Square sparkplug wire grommets
5. Chrome wingnuts
6. J-nut for R Chrome verticals.
(No instructions)
I'm thinking, after looking at a complete Kit at Corvette Central, that I still need some shield brackets that are bolted to the intake manifold??
Any help would be appreciated.
Old May 1, 2007 | 08:46 PM
kansas123's Avatar
kansas123
Old May 1, 2007 | 08:56 PM
SmokinBBC's Avatar
SmokinBBC
On my 70, there are 2 brakets bolted to the intake. The shielding attaches to those brackets. I don't know if yours is the same. Let me know if you want me to take a pic.
Here is what they look like. The small end goes onto the intake through the last intake manifold bolt. One on each side.
http://ecklers.com/product.asp?pf_id=36820&dept_id=1292
Old May 1, 2007 | 10:23 PM
chris73cpe's Avatar
chris73cpe
that is how the brackets mount on the manifold. I have the chrome shields somewhere too, but they're such a pain to get in place and straight, especially with my replacement washer pump and the ignition wires as high as they are.
Old May 2, 2007 | 07:36 AM
Plum Different 73
Thanks Chris - Are those orange brackets shown in your picture bolted directly to the intake manifold?
Old May 2, 2007 | 08:08 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
The AIM shows installation of all the shielding, plug wire routing, grommets and brackets, wingnuts, etc. Brackets shown above mount the distributor can and bolt to intake manifold. Two other brackets not shown in the pic mount on the block below the two shown for wire routing and vertical shield attachment. Way down under on the block are the left and right V shields.
Old May 2, 2007 | 09:13 AM
Plum Different 73
Mike,
Thanks for the info. Can you tell me where to find the AIM you mentioned?
Old May 2, 2007 | 09:42 AM
Plum Different 73
Thanks Smokin, but for some reason it seems like the big block installation is simpler than for the small block.
If you get time though, a picture might help.
Thanks again.
Old May 2, 2007 | 10:33 AM
corvetteload's Avatar
corvetteload
plum, assembly manuals available at any Vette parts supplier, and ebay!!!! Big block (69 at least) only had shield around distributor, not the PIA ones around the plugs..............................
Also to clarify, uprights don't BOLT TO the intake, they are held in place by 2 intake to head bolts, kind of misleading the post before. You have to remove intake bolts to put those 2 brackets on.................B
Old May 2, 2007 | 10:42 AM
Plum Different 73
Thanks.
Old May 2, 2007 | 11:48 AM
Easy Mike's Avatar
Easy Mike
Originally Posted by Plum Different 73
Mike,
All the aftermarket providers carry the AIM (assembly instruction manual). Order one for your year. Best deal includes a three ring binder for the AIM (pages are punched for the binder). You can also get AIMs off eBay.
Order a reproduction owner's manual while you're at it. If you have an original, put it up in a safe place and keep the repro in the car.
Old May 2, 2007 | 06:21 PM
Plum Different 73
I jumped in and did it today with a few modifications. Look at pics of before and after, and tell me what you think.
Thanks to ALL for your feedback!
Old May 2, 2007 | 07:48 PM
SmokinBBC's Avatar
SmokinBBC
Correct, I should have made this clearer.
Old May 2, 2007 | 07:54 PM
MikeMc71's Avatar
MikeMc71
I just bought all that stuff on E-Bay for less than $60.00.....brackets, chrome, bolts, the works. Its gonna need a little work, but there is always this stuff there.
Old May 2, 2007 | 08:19 PM
Frank O'Hara's Avatar
Frank O'Hara
I had quite a challenge figuring out the shielding for my car since it did not have any shielding on the car when I bought it I took a few pics for just this reason while the engine was out. Hope this helps - it's not obvious
http://bp3.blogger.com/_iz0bZq1hYKs/...h/P1010018.JPG
http://bp2.blogger.com/_iz0bZq1hYKs/...h/P1010017.JPG
http://bp0.blogger.com/_iz0bZq1hYKs/...h/P1010019.JPG
Old May 3, 2007 | 07:38 AM
Plum Different 73
Thanks Frank,
Your pictures DID answer some questions for me Also, it looks like you have a beautiful Vette from the engine on out!
Old May 3, 2007 | 07:02 PM
Plum Different 73
Done!
Thanks all!
To Need help with Ignition Shield installation
Old May 4, 2007 | 01:28 AM
kdf1986's Avatar
kdf1986
That looks good.
Did you also get the rubber grommets for the spark plug wires that go into the bracket. These have 4 holes in a square piece of rubber that will help to separate the wires.
kdf
Old May 4, 2007 | 06:09 AM
Plum Different 73
Thanks kdf. Yes, I got the grommets - a little tight for the 8mm plug wires though.
Plum
Originally Posted by kdf1986
That looks good.
kdf
Old May 4, 2007 | 08:20 AM
theandies's Avatar
theandies
What I would like to know if it really works? Does it cut down on ignition noise getting into the stereo? I have a slight ignition tick on FM and cannot even try to listen to AM. If it cuts the noise down some I'll think about getting some but if it makes no differance then I can spend my money on better things I need. I have to mention that my ignition is not stock. MSD 6AL box, blaster coil and billet MSD tach drive distributor.
