Marker Light Lens
Old May 1, 2007 | 11:19 PM
DollaGreen's Avatar
DollaGreen
Default Marker Light Lens
I did a search and found nothing on this. I am trying to find a replacement marker light lens for the back right side of my 73 (red lens). The lens has fallen out of mine. All corvette part sources I know of carry only the entire assembly for around $50. I only need the plastic lens. Where can I find one of these? Is it only possible to replace lens, not the entire assembly? Thanks in advance.
Old May 1, 2007 | 11:47 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
When I was looking all I was able to find was the whole assembly. Like you I had one missing but it was one of the front marker lenses. I wound up getting my car painted and bought all new housings and lenses for the whole car then. Try looking here. Still $49 though.
Old May 2, 2007 | 08:35 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Can't quote me on this, but I'm thinking the lens and housing are one unit so there would be no separate lens. Got an older auto salvage yard in your area? Side markers are not unique to Corvette and could have been used on other GM makes and models. Junkyard might have exactly what you want off an Impala, or a Nova, or a Chevelle.
Old May 2, 2007 | 08:43 AM
GD70's Avatar
GD70
Try Corvette Salvage 1-888-467-8388. They're in Mississippi but have lots of parts. I got a left hand wiper arm and rod for 40.00 from them.
Good luck.
Glenn
To Marker Light Lens
