door hangs
Old May 9, 2007 | 03:09 PM
cab's Avatar
cab
Default door hangs
i am sure this has been covered before. seems i cant ever find anything when i search. my driver door takes two hands and a tug to get open. i have moved the striker around and i still doesnt help. i know i will have to pull the panel but what do i need to be looking for. thanks.
Old May 9, 2007 | 03:20 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
First thing to figure out is where it's sticking. Lock pillar post? Hinge side?
Check the door lock mechanism to see if it's crudded up and not opening all the way. Might need a cleaning and a good lube.
Old May 9, 2007 | 03:24 PM
Glassbowtie77's Avatar
Glassbowtie77
If your door is sagging then either you have a broken hinge or the pins and bushings need to be replaced. Grab hold of the edge of the door and see if you can move it up and down, if so the hinges are your problem, most likely the lower hinge.
Old May 9, 2007 | 03:26 PM
Glassbowtie77
This is another option to check out as well.
Old May 9, 2007 | 03:29 PM
cab's Avatar
cab
failed to mention new hinges, pins and striker about a year ago. door has always kinda been tough to open when i got it, thats why i replaced all the above. that helped a little but has gotten worse.
Old May 9, 2007 | 03:42 PM
Glassbowtie77
I think your going to have to pull the door panel, it sounds like the latch mechanism is not working properly or the linkage rod from the door handle to the latch is out of adjustment. When you pull the handle inside the car to open the door does it open right up?
Old May 9, 2007 | 03:46 PM
cab's Avatar
cab
yes sir from the inside no problem. me and door panels dont get along.
Old May 9, 2007 | 04:05 PM
Glassbowtie77
It looks like that door panel is going to have to coming off. It's a good time to clean everything up in there. I would clean and re-grease the window tracks while it's off as well. If the vapor barrier is missing now is a good time to make one and reseal it to the door. Also make sure the drain hole at the back of the door is not clogged. I just did mine it's not that hard, just take your time and you should be fine. A digital camera helps to remember how and where everything goes in case you don't have the AIM or service manual for the car.
Old May 9, 2007 | 04:15 PM
Lon Wayne's Avatar
Lon Wayne
Default Vader Vette
Are you kidding I still have to use two hands and nothing is wrong with my doors.I think they are just heavy .Does your other door open easier?Are you getting A pattern in any sorounding glass.I would use thin paint tape, tape off the whole inside or the door area shut the door and see where the tape is messed up. and then maybe sand that area if you can.
Old May 9, 2007 | 04:34 PM
cab's Avatar
cab
the pass door opens fine. got to be something in the handle. it has gotten to the point when you pull up to the store and a bunch of people are around especially the other sex, so you leave the door cracked so you dont have to ******, put down whatever you bought to get in it so you wont look cool.
Old May 9, 2007 | 04:36 PM
Lon Wayne's Avatar
Lon Wayne
Default Vader
When you figure out what it is let me know im squeezing mine with both hands.
Old May 9, 2007 | 04:49 PM
cab's Avatar
cab
lon thats what i have to do man that makes me mad. will get the panel off and see what i can come up with.
Old May 9, 2007 | 09:29 PM
76vette1's Avatar
76vette1
Have you checked the stack of washers on the striker? If they are too tall, it will bind the door. Happened to me.
To door hangs
