Sandblast Cabinet Coating
Old May 9, 2007 | 06:39 PM
stinger12's Avatar
stinger12
Default Sandblast Cabinet Coating
I'm building a sandblast cabinet out of some very nice plywood at school. The plywood has a thin sheet of veneer on top of it (it is designed for building kitchen cabinets). It is coming along great. All the joints are smooth and it looks like a professional built it. I am concerned that the veneer sheet will wear off over time due to the sand hitting the walls of the cabinet when in use. I'm getting graded on this for looks and finish. I'll be using clear lacquer on the outside surfaces. But what about the inside? I need a material which will go on smooth and be hard as a rock when finished - I want to be able to protect the grain of the wood, not just paint over top of it. Is there any material out there that will suffice for the job? By the way, you have to be very careful when sanding the plywood because if you sand too much, you sand through the veneer and into the layer of plywood underneath it - this is why I am concerned that sandblasting will just eat through the veneer after the first use.
Any opinions?
Old May 9, 2007 | 07:01 PM
NHvette's Avatar
NHvette
Ah ... steel.
POR15 hardens up like a rock, but sandblasting media will still rip through it.
Hell, it will even rip through steel eventually.
I think you need to find a buddy in the metal shop to line it.
Old May 9, 2007 | 09:09 PM
stinger12's Avatar
stinger12
I'll be using a siphon feed blast gun, not the pressure type.
Old May 9, 2007 | 09:58 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
why not some galvanized steel from a duct work place? its probably 22 or 24 ga and it comes in big sheets...use a contact cement and glue it in place or screw it in
Old May 9, 2007 | 10:24 PM
comp's Avatar
comp
rubber sheet, cut and glue in
Old May 9, 2007 | 11:48 PM
SIXFOOTER's Avatar
SIXFOOTER
will last a long time
Old May 10, 2007 | 01:24 AM
stinger12's Avatar
stinger12
What about undercoating? Would that maybe work?
Old May 10, 2007 | 07:54 AM
gator79's Avatar
gator79
unless you direct the nozzle directly at the walls I don't think you will have a problem. you might try the aluminum plates from your local news paper printer. they are cheap and easy to cut
Old May 10, 2007 | 09:14 AM
eastltd's Avatar
eastltd
I have several hours on my steel cabinet and the internal paint is still in tact. I'd say, make it pretty and get the grade. You can always line it afterwards.
Old May 10, 2007 | 09:22 AM
cs_sas's Avatar
cs_sas
I have a pretty good size blast cabinet in my machine shop. The whole thing is made out of galvanized steel with the exception of the bottom where the blast beads return to the hopper below, that is 1" steel with 1/4" holes pattern into it. I have blasted many parts and all the walls on the cabinet are in great shape. My suggestion to you would be stick with something that has already been used and works. Galvinized sheets would be your best bet. Good Luck.
Claude
Old May 10, 2007 | 06:23 PM
stinger12's Avatar
stinger12
Good news, my shop teacher today informed me that he had some material for the inner walls of the cabinet today. He has 3 feet by 3 feet stainless steel sheet metal...he said it will work great for my project, will cost me nothing, aand will look good. Thanks for all the responses guys, looks like I'll be going with sheet metal
Old May 10, 2007 | 06:46 PM
NHvette's Avatar
NHvette
Free stainless . ?!?!?!
Wow - that is a SCORE !!!
Old May 10, 2007 | 06:50 PM
comp's Avatar
comp
Old May 10, 2007 | 06:52 PM
comp's Avatar
comp
i was thinking bed-liner..
post some pics for us
Old May 10, 2007 | 09:33 PM
stinger12's Avatar
stinger12
I'll post some pics of the cabinet when it's done. I can't wait to get it finished, it looks great. Should be finished in the next few weeks or so...probably sooner. I've made some plans up for the cabinet, so when the whole thing is finished, I'll post the plans as well. I've modeled the design after the 730-TL cabinet from TP tools - they charge about $300 I believe. This thing will probably cost me only $60 Canadian in materials, and it looks nicer too.
Old May 11, 2007 | 11:43 AM
comp's Avatar
comp
Old May 11, 2007 | 02:15 PM
Tom454's Avatar
Tom454
Sounds like you've got it licked, but I''ll add to the info here.
I stapled that cheap plastic carpet runner to the inside of my plywood sandblast box. It's been in there over 20 years.
A wooden box will erode very fast unless you cover it with something. You don't have to point the gun directly at the surface.... blow-bye is just as fatal to wood as a direct hit. Uncovered 2x4 portions of my box are pretty well chewed up.
Media will bounce off a rubbery material... lasts a long time.
.01 cents
Old May 11, 2007 | 02:27 PM
comp's Avatar
comp
.01 cents
the clear stuff never thought of that
To Sandblast Cabinet Coating
