68 ignition and door keys....same?
Old May 11, 2007 | 10:14 PM
AWilson's Avatar
AWilson
Default 68 ignition and door keys....same?
A lock smith told me that the 68 door and ignition keys are the same? Is this true? As far as I know GM always had 2 keys, one for the ignition and one for the doors and trunk.
Old May 11, 2007 | 10:34 PM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
Ignition and doors are the same key on my 68 and that is correct
Old May 12, 2007 | 01:33 AM
Z-man's Avatar
Z-man
In '70 there were two keys. One for the doors and ignition, the other for the glove box, spare tire, and alarm system.
Old May 12, 2007 | 07:11 AM
avalonjohn's Avatar
avalonjohn
CF Community Team
Veteran: Marine Corps
St. Jude Donor '25
Same key in 68, door / ignition.
Old May 12, 2007 | 07:47 AM
AWilson's Avatar
AWilson
Default how about the rear compartments and fuel cap
WOW, I never expected to be wrong about this one. So doors and ignition are the same. Is it also the same key for the rear storage compartment and spare for that matter?
Old May 12, 2007 | 07:57 AM
xCCTer's Avatar
xCCTer
CF JASOC Member
From: Downtown Annapolis, MD. The Future is where we all have to live. Let's not screw it up.
One key for the door and ignition on my '71.
Old May 12, 2007 | 12:15 PM
rihwoods's Avatar
rihwoods
69...one for ignition...one for doors...
Old May 13, 2007 | 10:45 AM
Beneja's Avatar
Beneja
My 68 has the same key for both.
Old May 13, 2007 | 07:37 PM
ksbunting's Avatar
ksbunting
Each 68 had 2 keys; one labelled "C" and one labelled "D"
The "C" key opened the doors and operated the ignition The "D" key operated the glove box and spare tire lock.
The keys were made by Briggs & Stratton and say Briggs and Straton on them and had the GM logo on them. The aftermarket phony keys do not have this.
They are still available and can be cut using the correct GM die cutter (not a hardware store wheel) and can also be coded with the correct numbers on the knock outs.
The "C" key is octagon shaped and the "D" key is oval shaped. The 69 keys were totally different
Kurt
Old May 13, 2007 | 09:25 PM
AWilson's Avatar
AWilson
Default ksbunting
Thanks for the info! Do you know where I can get the right blanks for cutting.
Old May 14, 2007 | 12:04 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
eBay. A vendor has correct '68 C and D key blanks for sale. Second vendor says he has correct '68 key blanks, but his are 70 or later.
Old May 14, 2007 | 02:14 PM
427-390's Avatar
427-390
Hemmings is another source. You may also want to check with any of the local locksmiths to see if they have any of the old key blanks around.
Old May 14, 2007 | 07:33 PM
ksbunting's Avatar
ksbunting
A Wilson
I got my originals (not repros) from a guy named Peter Lindahl at pclindahl@comcast.net
505-663-0995
He also rekeyed a tire lock for me that a large local locksmith had for three months and couldn't open.
Pete is outstanding at what he does and he is a Corvette guy
You won't be disappointed with Peter.
Kurt
Old May 14, 2007 | 09:31 PM
AWilson's Avatar
AWilson
Thanks I will contact him!
To 68 ignition and door keys....same?
