Quietest side pipe mufflers?
Old May 12, 2007 | 08:15 AM
Victor's Avatar
Victor
Default Quietest side pipe mufflers?
At some point during the last two years while I was working on restoring my '79 in Germany, the German government went and passed a law limiting the noise of a car's exhaust - or at least they are now forcing US military personnel stationed over here to abide by this law now.
I purchased my Hooker side pipes before they passed this law but I don't have the car registered yet so I'm going to have to get it to pass before I can drive or, more importantly, sell the car.
The car needs to be quieter than 90 DSB. I'm not sure how they do the testing, but I believe the rev the car quite a bit to get the volume at all engine RPM ranges.
I was originally looking at using Spiral Turbo Baffles (http://www.spiralturbobaffles.com) based on the feedback I've read on this forum over the last year. However, according to their webpage, the decibal range is from 85-95 from 750 rpms to 2000 rpms.
Does anyone know of any quieter muffler inserts??
Thanks in advance for any help I can get!
Old May 12, 2007 | 08:59 AM
woodlandcorvette's Avatar
woodlandcorvette
I have the spiral mufflers not sure of the db level but im thinking of adding vortex cones to lesson the noise. I know people will recommend reverse flow mufflers but they are restrictive and will lose alot of horse power. Glass packs another option but not sure how loud but heard they are better but then again will cut horse power levels. Not many other choices. Sweet thunders are as loud as sprirals from what ive heard. Maybe put reverse flows in to get registered and then switch to something that gives you better horse power.
Old May 12, 2007 | 09:08 AM
Edzred72's Avatar
Edzred72
Hooker reverse flow sidepipe mufflers are just as quiet as the original exhaust system. Had em on my 72 when I purchased it. Guys made fun of me because of it. They didn't sound like sidepipes at all!!!!
Eddie
Old May 12, 2007 | 03:36 PM
79C3kid's Avatar
79C3kid
6th Gear
I live in Wisconsin. If there is anyone out there that lives in WI could you please tell me what kind of trouble I could get in for running straight pipes. I don't know how loud the car will be, but I love loud cars. The only problem is that I don't think the police will like it. So if anybody can help me out, please do.
Old May 12, 2007 | 03:45 PM
Duke94's Avatar
Duke94
Eddie
They are quiet but VERY restrictive. The glass pack Hookers are louder, not sure if they meed 85db but they are restrictive also.
Old May 12, 2007 | 04:11 PM
xCCTer's Avatar
xCCTer
CF JASOC Member
From: Downtown Annapolis, MD. The Future is where we all have to live. Let's not screw it up.
First off, I LOVE MY SIDEPIPES.
You'd better give some additional consideration to the straight pipes thing. Your engine needs a certain amount of back pressure to operate correctly. With straight pipes you'd lose A LOT of low end power. It would be loud though.
Here's a little story...
When I bought my last Harley in '99, they didn't have a set of drag (straight) pipes for it, so I took delivery of it with the stock exhaust and ordered what was basically chrome tubes.
I couldn't believe how great it ran, and was thinking that HD must have really tweaked the engines since the previous new Harley I bought in '93. Did I like the sound? No, but the drag pipes would be in in a week or so.
The new pipes came in, and I was there the same day and put 'em on. The loss of low-end power was incredible. Once I got up over 40mph was another story, and it did sound like what I want my Harley to sound like though. I ended up buying a set of baffles that fit inside the drag pipes and couldn't be seen. That seemed to give me a happy medium I could live with. If I'd never driven it with the stock exhaust, I'd have never known the difference.
Just something to think about. Side Pipes, BIG YES! Straight pipes
Good Luck.
Old May 12, 2007 | 11:21 PM
Glassbowtie77's Avatar
Glassbowtie77
I'm in the process of buying Hooker sidepipes also and can't decide which way to go, reverse flow or glasspacks. I wish I could hear how each would sound beforehand so I that I could make the right decision. I don't want it to be as quiet as the stock exhaust, but I also don't want it to be too loud either because the pipes are now right along side of you when you drive as opposed to the sound coming out of the back of the car. I don't want too loud so that I can't hear myself think, but I would like that deep throaty sound. Do they have sound clips anywhere to listen to so you can get an Idea of how'd they sound?
Old May 12, 2007 | 11:59 PM
randommj's Avatar
randommj
id go open headers with cut outs, STICK IT TO THE MAN!!!
Miles
Old May 13, 2007 | 01:03 AM
Z-man's Avatar
Z-man
Do you have to get the inspection every so often? Get some old, used Hooker reverse flows (on the cheap) for the inspection, then remove them and install the spirals for every day use. Whenever you need to retake the test, put the reverse flows in temporarily.
I really like my spiral turbo baffles, but I doubt if they would pass the test when you really get on it...
Old May 13, 2007 | 02:12 AM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Considereing changing from glass-packs to max-flows, I've got some "like-new" reverse flows I don't ever intend on using, if you're interested...
Old May 13, 2007 | 09:30 PM
Rodbuster's Avatar
Rodbuster
The way to cut the sound is to cut the flow. Lets say you had a set of STS baffles in your side tubes and left the center cap on and not drilled. If you than took a piece of sheet metal cut four 4 inch circles to use like plugs. Than drill lets say 30 3/16 holes in the plugs than tac weld them to each end of the STS baffles that would stop the flow.
Old May 14, 2007 | 01:01 AM
Victor's Avatar
Victor
Thats what I was thinking, but I'm going to turn around and sell the car as soon as I can get it to pass inspection. To make a long story short, I'm moving back to the US in 5 months and I can get A LOT more money for my '79 over here than I could ever in the states (like $5-$10,000 more).
Thats a great idea. I'll have to look into that.
Thanks!!
Victor
Old May 14, 2007 | 01:21 AM
SHAKERATTLEROLL's Avatar
SHAKERATTLEROLL
This looks like the way to go then if you are just going to sell the car.
To Quietest side pipe mufflers?
