aux cooling fan
Old May 13, 2007 | 08:20 AM
cajos's Avatar
cajos
Default aux cooling fan
I have an additional cooling fan on my radiator. It can be swiched on with an additional swicht in the mid console. I want to automate this fan with a sensor on the radiator.
Who knows a kit with a thermostat and a adjustable "switch on" used for this purpose. Please send me the link.
Old May 13, 2007 | 10:10 PM
Durango_Boy's Avatar
Durango_Boy
This is one of the best there is is. I ordered the 35 amp controller and will be installing it this fall when the new motor and trans go in.
http://www.dccontrol.com/
Go to fan controllers.
Old May 13, 2007 | 11:45 PM
SIXFOOTER's Avatar
SIXFOOTER
That fan is just a helper fan for driving in heavy traffic moving slow. It doesn't move a lot of air. Thats a pretty expensive controller, I have one but its going to be running a dual 12" electric fan setup.
Old May 14, 2007 | 04:26 AM
cajos's Avatar
cajos
Same thoughts here; remember I'm Dutch and we don't like spending money ;-). HAHA.
Seriously, If it was my primary, it would be no problem, but it is just as sixfooter writes. Looking for something cheap to automate the switch.
regards
Old May 14, 2007 | 07:56 AM
MikeMc71's Avatar
MikeMc71
try this:
http://www.ecklers.com/product.asp?p...3&dept_id=1252
Old May 14, 2007 | 08:15 AM
cajos's Avatar
cajos
Thanks Mike,
Its a bit over done. There must be a cheap DIY alternative!!
Regards
Cas
Old May 14, 2007 | 09:22 AM
SIXFOOTER's Avatar
SIXFOOTER
These guys have senders
http://www.lectriclimited.com/mainpage.htm
Old May 14, 2007 | 09:48 AM
hourang's Avatar
hourang
8th Gear
your local autozone should have a cheap kit
Old May 14, 2007 | 11:11 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
What year? 79 and 80 L-82 cars, and all 81-82 models have factory electric auxilary fans. An additional temp switch is installed in the RH head and powers the auxilary fan when temps rise to the specificed level. Get the 80-82 AIM and take a look at the installation.
Old May 14, 2007 | 11:39 AM
cajos's Avatar
cajos
It's a 72 Coupe 454
Old May 14, 2007 | 11:57 AM
Easy Mike's Avatar
Easy Mike
Originally Posted by cajos
It's a 72 Coupe 454
Check right head for a bung for an additional temp sender.
To aux cooling fan
