Thoughts on Protect-A-top?????
Old May 14, 2007 | 02:19 PM
AZ78Vette's Avatar
AZ78Vette
Default Thoughts on Protect-A-top?????
What do you guys think of this Protect-A-top from mid america? I like to drive without my tops but i do not have room in the back (i have a 12 inch sub ) and i was seeing if anyone has used this and what they thought. here is a link to mid america
http://www.madvet.com/shop?frame=4.163.705
Thanks!
Old May 14, 2007 | 02:54 PM
Jims79's Avatar
Jims79
Is that top only for parking? I didn't think you could drive w/it like incase of rain. Ecklers have a top like that which you can drive with.
Old May 14, 2007 | 03:55 PM
AZ78Vette's Avatar
AZ78Vette
i am not to worried about driving with it i was just wanting to know how well it holds up and how secure it is?
Old May 14, 2007 | 09:33 PM
gyopp's Avatar
gyopp
I have the one from Ecklers which seems to be fine for its intended use. I have had the car up to around 75 and it did not blow off but it did have a lot of air leaks. All I wanted was an emergency rain cover and its fine for that but as far as secure like from theft or intrusion? Might as well save your money.
Old May 14, 2007 | 09:55 PM
VettePower's Avatar
VettePower
I'm sorry, but there is no way that thing would stay on at 75 mph!!!
Old May 14, 2007 | 10:05 PM
gyopp's Avatar
gyopp
Well, if you get up this way let me know and I will take you for a ride. I ran it down the interstate about 15 miles at that speed and it didn't come off.
BTW, if your gonna call , make sure it is
Old May 14, 2007 | 10:13 PM
VettePower's Avatar
VettePower
I tell you what. Take a pic of your Vette with that top on it, and I will take it back. Otherwise,
Old May 14, 2007 | 10:20 PM
gyopp's Avatar
gyopp
from Eckler's product description:
"All "Rain Coats" have been designed and tested to be used at normal highway speeds with no problems."
If yours wont stay on maybe you should have read the instructions.
Old May 14, 2007 | 10:37 PM
VettePower's Avatar
VettePower
Maybe you should learn to read. The topic was about Protecto-top, from Mid America, not the rain coat, from Ecklers!! Now what is your snappy answer??
Old May 14, 2007 | 10:47 PM
gyopp's Avatar
gyopp
Old May 14, 2007 | 11:09 PM
Bangkok Dean's Avatar
Bangkok Dean
How easy is the Rain coat to install? Also does it have to have securing points left on that interfere with the T-tops later?
Old May 14, 2007 | 11:18 PM
gyopp's Avatar
gyopp
It's easy Dean, it attaches to the oem t-top mounts and has 2 velcro straps that fasten around the center bar. It comes with self adhesive velcro sealing strips for the front and rear that take about 10 minutes to install.
Old May 14, 2007 | 11:21 PM
Bangkok Dean
To Thoughts on Protect-A-top?????
