Correct Ride Height Above Tires?
Old May 14, 2007 | 03:51 PM
James1970's Avatar
James1970
Default Correct Ride Height Above Tires?
What's the correct ride height of a C3 above the front/rear tires?
My 70' w/225/70-15's sits real low. Top of the tires are under the wheel wells.
Yes, it does bottom out! In fact, I'm taking it in tomorrow for suspension work and would like to know what to tell the mechanic with respect ride height.
Thanks for your input!
James1970.
Old May 14, 2007 | 04:42 PM
rihwoods's Avatar
rihwoods
James1970.
That won't work....it all depends on the type of spring(s) you/he selects...not to mention adjustments for rear spring and all that goes with that...so you will be adjusting no matter what...
Rich
Old May 14, 2007 | 06:41 PM
mikebaskette's Avatar
mikebaskette
Default Rich is right
Springs are supposed to have arch.....sounds like yours is the anti-arch kind. Just remember, higher weight spring does not mean better spring. Took my '70 out for a lively spin yesterday with its 315 spring, newly installed, perfect. Even with my dopey neighbor with me.....my god he is a dope. And I thought my dog was a mouth breather.
Old May 14, 2007 | 06:47 PM
NHvette's Avatar
NHvette
This would also depend on the diameter of the tire.
I recall about 28-29" from ground to fender edge with stock tires.
A larger diameter tire would make the fender higher and the
wheel seem to be tucked up under more.
Space for stock tire to fender edge ... about 1-2".
Old May 15, 2007 | 01:00 AM
James1970's Avatar
James1970
Thanks everyone.
I've decided (after much consideration) to stay with the 225/70-15's tires that are on the car (Goodyear Eagle GT II). My plan is to keep the suspension stock. I believe I'm looking at new springs, shocks, leaf, bushings. etc.
The springs and leaf are original as far as I can tell. The leaf has no visible bow. Thinking steel heavy duty 7 leaf spring with street/slalom front springs might do the trick. But what do I know?????
I'll see what Johnson's Wheel Alignment says tomorrow morning. The shops been around for 30+ years so I'm hoping they've worked on a vette or two. I'll be pleased if he car sits 1" to 1-1/2" above the tires when complete.
I'll keep you posted.
Old May 15, 2007 | 12:56 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
...Thinking steel heavy duty 7 leaf spring with street/slalom front springs might do the trick. But what do I know?????...
With respect, if you actually don't know the changes the slalom springs and HD rear will make, do a little more homework. The ride is likely to be very stiff with the changes you are considering.
If you want a bit more control without the rocks-in-your-pockets ride, take a look at installing a stock rear sway bar from a big block or FE7 car and stock front and rear springs. You'd get standard ride height and the beneifts of the rear sway bar.
Old May 15, 2007 | 05:02 PM
Tim H's Avatar
Tim H
Pat yourself on the back for making the best right choice you could make!!!!!!!!!!!!!!!!!!
OOOHHH JJEEEZZZE what a mistake you could have made in picking tires.
The other day at a tire shop, the owner of a 76 was talked into swapping out his 8 in. rallies for some 7 inch and 215/65/15s.
You talk about gruesome!!!!
I asked the guy why did he just do that and he said the tire shop people recommended it?
He ask me what I had on my car and I showed him and he said they would rub on his car.
I don't know about you, but A 76 and a 77 ain't that different.
but thats why I learn about stuff and others let somebody do their thinking for them!!!
Old May 17, 2007 | 01:26 AM
James1970's Avatar
James1970
Thanks for your input Easy Mike.
The mechanic at the alignment shop called this afternoon after reviewing the suspension. The existing 9-leaf had a negative bow (I knew that) and the shocks and bushings needed replacement.
Here's what he's doing:
1. New 9-leaf with bushings and 8-1/2" bolts (I believe he said the stock bolts were 6-1/2" and the 8-1/2 will give him room for adjustment (?).
2. Bilstein shocks front/rear
3. New bushings up front
4. Lube chassis
5. Change differential fluid
6. Adjust steering to remove "play".
7. Align front/rear
8. Check back-up light wiring for proper hook-up at tranmission
9. (2) Goodyear Eagle GT II's to match front set.
Your comments regarding the 7-leaf was duplicated by the mechanic. I appreciate your comments Mike.
Tim H:
Appreciate you comment also. I wanted to go 60 series but decided not to chance all the hassles associated with them. The 70's look/perform fine plus I would only have to purchase 2 tires, not 4.
BTW, The Goodyear Eagle GT II has a crappy rating on TireRack. However, the front set on the car have performed well and have way too much tread left to replace. Easier to buy 2 for the rear and let all four age together.
Thanks gentlemen.
james1970
Old May 17, 2007 | 12:45 PM
Racer11's Avatar
Racer11
I opted for installing a mono spring in the rear instead of replacing with a leaf spring set up.
That was the smartest thing I did was getting rid of the leaf set up.
Old May 17, 2007 | 01:14 PM
GD70's Avatar
GD70
Here's the 70 AIM page showing ride height specs.
Glenn
Old May 17, 2007 | 06:18 PM
LT1driver's Avatar
LT1driver
no measurement from top of tire to fender, GD70 has it right.
Old May 19, 2007 | 01:05 PM
ddecart's Avatar
ddecart
SPARTAN
CI 3-4-5-6-8-9-10 Vet
CI-9 AutoX Winner
CI-3 Go Kart Champ
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11
Any chassis engineer will tell you that the body guys aren't reliable. Consider how poor body fits were back then and how much variation bodies had. Then think that they're connected to the chassis (with it's own variation) with shims between the two. It's not hard to see why you measure the suspension instead of the body.
On that AIM page, use the Z & D heights.
Old May 25, 2007 | 03:56 PM
James1970's Avatar
James1970
Default Suspension Refurbishment Complete. Results:
I wanted to close this thread with an update:
I picked up the car from Johnson's Wheel Alignment (Torrance, CA) on Tuesday night and I'm delighted!
The new Bilstein shocks, 9-leaf spring, bushings, alignment (front/rear) and rear tires make this a different car. The ride height is perfect (level with about 1" clearance from top of tire) and no bottoming-out!
It's going to take me a while to get comfortable with the new feel of the car.
Thanks again for all who provided input. I do appreciate it.
Best,
James1970
Old Nov 8, 2007 | 07:41 PM
goatsandvettes's Avatar
goatsandvettes
Default Wonder if I have some really wrong
From the top of my 235/60 15's to the bottom of my back fender is a full 5 inches... I measured them today.. also measured the height of bump from ground to about center (i check the same place on both sides) and it was 24 or 25 inches.. i was just curious is both sides were even.... have I got tires too small or does my vettes butt just sit high
Old Nov 8, 2007 | 11:45 PM
MakoShark72's Avatar
MakoShark72
Wouldnt you guys think 5" is a little excessive???
Old Nov 10, 2007 | 12:44 AM
goatsandvettes
Default That is what I am wondering
Reminds me of when I put Monroe Load Levelers on my 67 Camaro and everyone thought I had jacked it up as we called around 1971
To Correct Ride Height Above Tires?
