Drivers rear view mirror
Old May 14, 2007 | 08:10 PM
Bond007's Avatar
Bond007
Default Drivers rear view mirror
Hello fellow vetteheads,
Could someone let me know how to find the website that shows how to shim up the ball on the mirror to keep it from sagging. I saw it in illustration form and can not remember where I saw it and how the shim went in. I already have the mirror off, but want to install shim right, so i won't have to do this again. Driving me nuts.
Thanks in Advance
Old May 14, 2007 | 08:45 PM
Mick42767's Avatar
Mick42767
Look here: http://www.corvettefaq.com/c3/chrome_mirror.pdf
Old May 14, 2007 | 09:12 PM
Bond007's Avatar
Bond007
THANK YOOOOOOOOOOOOOOOOOOOOUUUUUUUUUUUUUUUU
I CAN SLEEP TONIGHT I SCREWED IT UP ALREADY I GROUND OUT
ONE RIVET AND TRIED TO PUT A SCREW IN THE RIVET HOLE IT DID NOT WORK HAVE TO GET CREATIVE ANY IDEAS???
Old May 14, 2007 | 10:06 PM
GD70's Avatar
GD70
Use the JB weld to make a new "rivet" so to speak. Smush it in where the old one was and reassemble before it sets up as the link explained. Or you may just need to replace the mirror.
Glenn
Old May 17, 2007 | 04:46 AM
Bond007's Avatar
Bond007
Thank you GD70
Old May 17, 2007 | 08:03 AM
sweethence's Avatar
sweethence
From: Wilmington DE, Drive it like you stole it, 68 327 4 speed coupe
Glenn
same problem, fiddled with it shimmed wahsered, wadded up piece of paper ..........
replaced mirror, problem solved
Old May 17, 2007 | 08:20 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by sweethence
...replaced mirror, problem solved
Old May 17, 2007 | 10:18 AM
justanotherdoe's Avatar
justanotherdoe
I used a small shim cut from a bicycle inner tube. Now the mirror stays where you put it, doesn't squeek, and I was able to leave a bit of bubba for the next owner to find
Old May 17, 2007 | 02:29 PM
GD70's Avatar
GD70
Thats a great bubba fix! Wish I 'd a thought of that.
To Drivers rear view mirror
