79L82 spedo not working
Old May 14, 2007 | 08:39 PM
nekkutter's Avatar
nekkutter
Default 79L82 spedo not working
First off thanks to those that helped me with my Tach, I replaced the board itself and BAM!!!! the thing worked, Now the spedo is not working. I took the cable off from the trans hooked a drill up to it and SLOWLY turned it the spedo and cable are good to go, ends and all are square...however I went a step further and pulled that gear out of the housing and it showed some wear at the tip where the cable end goes in. Sooooooo could this plastic piece be the problem?
