Radio bezel interchange.
Old May 16, 2007 | 01:31 PM
sdkid's Avatar
sdkid
Default Radio bezel interchange.
Are the gauge/radio bezels diferent from 77 to 78? Can the 77 be mod to fit?
Old May 16, 2007 | 07:09 PM
Durango_Boy's Avatar
Durango_Boy
They are almost the same and should interchange just fine.
Edit - A '77 bezel can fit in a '78, but probably not the other way around. Sorry, I humbly stand corrected.
Old May 16, 2007 | 07:20 PM
sdkid's Avatar
sdkid
Thank you.
Old May 16, 2007 | 08:02 PM
Durango_Boy
Thank you.
Yep. Good luck.
Old May 16, 2007 | 10:18 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
The 77 bezel has small plastic "wings" on the side to interface with the 68-77 style dash side panels. It's not hard to cut some textured ABS plastic to epoxy in place so that a 78-82 bezel can be used on a 77.
Old May 16, 2007 | 10:20 PM
Durango_Boy
The '78 I worked on had a bezel exactly the same as my '77. Do you think it was a mid year change in '78?
Old May 16, 2007 | 11:20 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
The 77 bezel is a one-year part, #8989948. 78-82 (with clock) is #25017278. A 78-82 bezel will fit in a 77, but will have a gap on each side between the bezel and the knee pad. I doubt a 77 bezel would fit in a 78-82, the side walls would interfere with the dash. It looks the same from the front.
Here's a pic of a 78-81 bezel sitting on top of my original 77 bezel. You can see the wings next to the radio on the 77 part.
Old May 16, 2007 | 11:30 PM
Durango_Boy
My previous post is edited. Sorry.
Old May 16, 2007 | 11:42 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
No problem...I thought they were the same for years. The difference isn't obvious unless someone points it out.
Old May 17, 2007 | 07:13 AM
Ganey's Avatar
Ganey
http://forums.corvetteforum.com/show....php?t=1241595
Changed to the later cluster awhile back replacing the clock w/ the later oil temp. gauge though it fit in the 77 cluster. This makes the gauge openings same.
Old May 17, 2007 | 08:28 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
The 77 bezel is a one-year part, #8989948...
Yep. 77s have the older dash pads and the new center cluster and console. 78 up, the dashes changed.
To Radio bezel interchange.
