68 steering wheel
Old May 19, 2007 | 10:06 PM
1978shark's Avatar
1978shark
Default 68 steering wheel
I looked at a 68 today and had a question about the steering wheel. I know they came with a 16 inch diameter wheel which seems huge. The thing is so close to the seat bottom that it is tough just to slide your right leg under it when you enter the car. My questions are: Did they make a tilt/telescope, is there any adjustment up on a stock column, and has anyone found a way around this?
Thanks!
Old May 19, 2007 | 10:27 PM
PRNDL's Avatar
PRNDL
68s had a tele option, but no tilt. I have the tele, and it is useful, but more useful to be bowlegged if you have a 4spd.
Old May 19, 2007 | 11:28 PM
big_G's Avatar
big_G
Thanks!
You could do like I did and just put a wheel from a '69-up on. They are a little smaller.
Old May 19, 2007 | 11:31 PM
68RATVT's Avatar
68RATVT
First switch to a 14" inch wheel, then to get in without blowing a knee, you sit then swing in. And don't drive with big shoes or flip flops,aint goin ta work in a quick situation.....
Old May 20, 2007 | 02:19 AM
427SIXPACK's Avatar
427SIXPACK
2025 C3 ('68-'73) of the Year Finalist - Unmodified
2024 C3 of the Year Finalist - Unmodified
No factory adjustment on a 68 stock wheel unless you have the tilt / tele option.
Moving to a 69 wheel will not solve anything, it's only 1" smaller.
SOLUTION:
Buy a 1968 CADDY............plenty of leg room
Old May 23, 2007 | 11:40 AM
Shu68's Avatar
Shu68
Default 14" Wheel
I have a '68 with the same issue, rack my shin getting in and out. The steering column seems unsually long, but have looked all over the column and can not find any type of telescoping ring release to move it, so it must be standard.
I was thinking of (at least temp) installing a 14" wheel to save my shins while I drive it around.
Has this work for anyone and is the standard column that long?
Thanks,
Shu
Old May 23, 2007 | 01:15 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Huh...new one on me. I don't whack anything getting in or out of my '68. She's running the old, original, 16" wheel.
Old May 23, 2007 | 03:04 PM
superdad60's Avatar
superdad60
Keep the original for when you are 70 years old and have thinner legs and get a 14" today while fat and sassy....
Worked for me
To 68 steering wheel
